paul fortman said:Ok, Make sure you change the speed controller also, it will need to be a variable speed controller.
Just in case you wasn't aware.
Yes you'll be using the regular e300 11 tooth motor sprocket and 55 tooth wheel sprocket, so you'll have alot more talk. Much better for gradients.
Just make sure the batteries can cope with the extra power.
Sent from my SM-G935F using Tapatalk
I'm entirely sure tbh so I wouldn't like to say one way or another.CStratton said:paul fortman said:Ok, Make sure you change the speed controller also, it will need to be a variable speed controller.
Speaking of batteries, I planned on just using some 6s lipo packs from my RC airplane junk. But the more I read around here everyone seems to be using Samsung 18650 round cells? Is this the same chemistry or slightly different? I assume the round cells would be better for durability? What is the advantage of these round cells over the soft cells?
1300 miles! Holy moly, how much do you ride?paul fortman said:I'm entirely sure tbh so I wouldn't like to say one way or another.CStratton said:paul fortman said:Ok, Make sure you change the speed controller also, it will need to be a variable speed controller.
But If I was to recommend an extremely great reliable battery for your e300 then it is this one below. It plugs straight into the e300 controller or aftermarket controllers.
I've done 1,300 miles on mine so far and the battery is as strong as day one. The battery is good for around 3000 miles and is a very reasonable price.
It fits very tightly into the battery tray and there's enough room for the controller too. You just have to manipulate it all to fit but it all fits very well.
https://www.mafscooters.com/brand-new-lithium-polymer-life-po4-7ah-24volts-battery-and-charger-122-p.asp
paul fortman said:I literally ride it every single day, I used to ride a Honda CBR fireblade, and I bought my son a razor e300 for his birthday and had a go of it (as you do haha) and I thought to myself "I bet I could upgrade the spec for me to ride one". 2 years down the road I'm commuting on it every day and build them from scratch. I just buy them second hand for cheap and then strip them down and replace everything to a much higher spec.
Such fantastic machines they really are.
Haha,CStratton said:paul fortman said:I literally ride it every single day, I used to ride a Honda CBR fireblade, and I bought my son a razor e300 for his birthday and had a go of it (as you do haha) and I thought to myself "I bet I could upgrade the spec for me to ride one". 2 years down the road I'm commuting on it every day and build them from scratch. I just buy them second hand for cheap and then strip them down and replace everything to a much higher spec.
What are the specs for the one you commute on if you don't mind me asking? I want to build one able to yank my 210 lb ass around? Lol
