Hillhater said:
JackFlorey said:
Exactly the same. You are then in a glider.
Actually you are a little better off in an electric vehicle. You can dive the aircraft to recover some energy through regen. Can't do that with a recip or turbine. Nice to still have the ability to stretch a glide if you need to.
“Stretching a glide” and ... “dive to recover energy through regen”... would appear to be contrary concepts ?
How much regen energy could actually be recovered in a >5000ft dive ?? .... ( 1-2 munutes ??)
And all the time the electric aircraft has the same battery weight
..and in reality that battery is probably +_ 1000kg dead weight. !
Yes, they are.
Let's say you are far from an airport. You are then better off in an electric aircraft, since the freewheeling torque from an electric motor is far less than the torque from an IC engine - and it's easier to stop the prop if you want to reduce drag further.
Let's say you are right over an airport. Then you can dive the aircraft aggressively and recover power. That lets you go around perhaps once if you screw up the first approach.
Propeller efficiencies are around 80-90%. Let's say you get an additional 85% from the inverter/battery system and you lose another 20% to drag. That's (.85*.85*.80)^2 = 33% of the energy that you can recover and put back into useful thrust. So from 5000 feet you can attempt a landing, go around at 5 feet off the ground, and climb back to 1600 feet - better than pattern altitude.
Which helps you on the way down and hurts on the way up.
