Electric motor will not start up.
RLTW175
Good morning from AZ. I have a Motenergy ME1305 PMAC Motor with a SEVCON Gen4 controller. I am getting an 8 flash trouble code on the controller and the motor will not start-up. (Diagnostic page from manual attached) It was working fine until I attempted to connect battery voltage meters to each battery in order to monitor voltage. Due to my lack of knowledge with DC current and batteries in series. When I attempted to connect voltage meters one shorted out and think this is the catalyst to my issue. What might of my actions damaged?
There aren't any attachments. ?
For us to tell what might have gone wrong, you would need to post your system's complete wiring schematic, *and* exactly how you connectded the voltage meters, *and* what they were set to if they are multifunction meters (if they are *just* voltage meters, there probably are no settings), *and* exactly which meter they are (a link to where they came from could be helpful).
Without that information, anything would be a guess, at best. :(
But there should be no way to connect a voltage meter across a battery, that could damage your controller.
