WasabiSausage
- Joined
- Nov 6, 2022
- Messages
- 4
Hello,
I currently have a gas winch that I am looking to switch to electric. I have stalked this forum a bit and the motor typically used for this was an Astro Flight 3220 modified to be 3 turn. I came with very little knowledge to this forum and have gained enough to know I'm clueless :lol:. I have my current winch attached, it has a Predator 212 with 8 lb/t and 6.5 hp with the governor removed so it's more around 8 hp and 5000 rpm (from 3600). As I mentioned, I'm looking to switch to an electric motor but would like to still have the same power/speed. Weight is not really a concern since it's already super heavy, so all motor types are acceptable. What kind of motor would be the most cost effective to replace my current engine? From what I understand I should be looking at 8-10kW motors that can rev to 3-5K RPM but I'm getting results from alibaba and other sketchy websites which make me think lots of the motors I'm looking at won't actually be good. I'm not exactly sure what a legit motor capable of my needs costs because there are so many false ones out that I come to you pros for advice! A high quality E-Winch called Rewinch has these specs which may help a motor recommendation:
- 12kW
- 300kg pulling force
- 48v battery pack
- Speed of 25mph (40km/h) but also has a speed mod for gearing to go up to 50mph (included because 12kW seems overkill based off this, I don't need super torque or super speed)
- I'm pretty sure it's made with 2 brushless motors, but they don't reveal their secretes
