Gtech
Hi all,
I build my own first winch for some fun on the water, here you can see it in action:
https://youtu.be/MrMor7LJufQ
Picture:
https://imgur.com/gallery/9qiXco9
I'm now using a HS3540 on lipo 18S 10ah with a lyen controller 18 fet sensorless controller.
The problem is that I am struggling with enough power. When doing a wakeboard waterstart it draws 80a for a few seconds before turning to 5a/6a. But for proper waterstart think I need 125a/150a for 4/5 seconds.
Guess I also sort of killed the lyen controller today, it still runs when there is no load but when you put it to load it totally stalls after less then a second to zero rpm.
After each run I checked the temperature of the battery, motor and controller and all was not above 25 degree Celcius.
Do I need a heavier controller or did I just got unlucky with this second hand one?
On 18S speed is OK, just need more starting power.
I will try to find the printscreen of the settings I used I believe is was something like 80a cont / 200a peak
Hope you guys can help me out.
Kind regards,
Marcel
Picture:
Kind regards,
Marcel
