sinisterminique
- Joined
- Jun 15, 2019
- Messages
- 17
Hi, If you have been on youtube lately looking at free energy videos,chances are you came accross a guy named gerard morin like i did.
This guy discovered a bunch of interesting things but what got my attention is the BLDC pancake motor that he found in front load washers such as fisher-paykel,LG,Samsung and others.
The main point here is that these motors have 2 main qualities,1- they are no longer under any patent therefore open to all and 2- they are very powerfull,the torque goes up with the speed while the amps go down.
The torque on this thing is so powerfull that in israel,they turned a 25 000 watts generator with it... think about the potential.
With this motor running properly,you could power an entire house all year long,no matter how cold it gets out there.
That's the problem we need to solve to use this motor,make a proper controller for it as none exist on the open market still to this day.
I'M currently in the process of making a mechanical controller for it so it can run on high voltage.The purpose of a mechanical controller is to be able to dump in the motor whatever voltage i wish without the limitations of electronics components, we could call this new controller a "Limitless High Voltage Controller" or LHVC.
I need help with this project as my ressources are limited but if we all put our heads together we can make it.
My goal just like gerard's,is to open source everything and let it all out there for hummanity to play with,we can end the monopoly of the energy industry (petrol,electricity),with these motors we can power the whole planet.They can be used to make electricity,power your house,power your car or truck or plane or boat.anything...they even currently use them in russia as a step by step motor for the biggest minning crane in the world...and in japan this is the maglev system that powers high speed trains floating on magnetic fields.(they took the track and made it into a circle and now we have this motor)
At the moment,some folks have modified these motors to use them for hydro power or wind turbines,they changed the voltage to what they need by modifying the winding configuration and such but none has made a controller that was efficient at high RPM.I even saw someone power a trike by using this as a hub motor and the bike was doing some very decent speed but running on batteries.
The issue at the moment is that the best controller made so far can only spin this motor at a around 3-4K RPM but sometime after 2000 RPM the torque starts going down seriousely due to timming not following properly at higher RPM'S.
All the controllers out there,vfd's esc's and such...they dont work good for high speed and torque,they will get your maybe at 1500-2000 rpm (being generous here) then you loose timing.
A few specs about this notor:
Altho when you see it at first it looks like a regular three phase motor,it is not,so an esc will rotate it but not properly and it will growl at low speed and shake alot. The stator winding is a "wye" configuration but for the timing to works properly at all speeds it needs to fire in sequence as if it was a 3 cylinder engine but firing in line so 1-2-3,1-2-3 and so on.A distributor will not work.
So far i have determined the following,the stator has 36 poles,each set at 10 degrees apart,the "power on" for each sequence lasts 6 degrees and the "power off" lasts 4 degrees then next pole is powered up for six degrees and so on..
Everybody so far is trying to build an electronic controller for this but none succeeded in building one that can do say 6000 rpm and still have high torque,they all have issues with the timing it seems.thats why i want to make a mechanical device somewhat along the principles of a distributor but needs to be different as a car distributor off the shelf will not do,nor will the computer for the timing.
As an experiment,i would like to be able to dump all the voltage i want in that motor and spin it till rupture...just to see how many rpm this motor can witstand,wouldnt that be fun to see
On a more practical side,high torque at 4000 rpm IMO would be plenty to run a 25 000 watt generator to put our houses off-grid.
It also has been proven that it is possible to self-loop this motor with a generator,making the generator self-sufficient.(was done with a 10 000 watts generator by gerard morin)
All theses videos are on youtube so you can check it out by yourself.
So if any of you folks are familiar with arduinos and such,i was looking lately at a controller from renesas company,the model RX23T kit wich supposeddely auto tunes the controller to the motor,has anyone tried this yet as it seems to be a good candidate for an electronic controller.
I will post pics soon of my "in progress" mechanical controller,wich i am trying to build by hand with off-the shelf parts.... wish i had access to a 3d printer.thats my next purchase...
If anyone wants to jump in,we could all benefit from freedom from the energy cartels and frankly i need all the help i can get to get this thing turning properly.
Just to be clear, i dont want your money i want your help in making this work so we can all benefit from it.other ppl have spent the money already on other parts of this project,all we need to do is come up with a reliable controller that could run at 4000 RPM 24/7 and then kiss the energy bill goodbye.
You can make all the money in the world,it will never be enough to pay all your debts,the solution in that case is to get rid of the debts,energy is the biggest bill we pay,i have no objection getting rid of that,how about you?
