SackofFluor
- Joined
- Jun 26, 2021
- Messages
- 10
Hey Guys,
Sorry for pestering you with such an easy question, but I am a little los when it comes to "bus bar sizing"
Lets imaging i want to use a 24v Battery and a 24v inverter to draw 3600 Watt of power at 220V.
When dividing 3600 Watts by 24V I end at 150 Amps.
Do I understand correctly that at the Plus and Minus Pole of a 7s 19p Battery the bus bars have to be around 16x 1.6mm of Pure copper?
( I used this table as a reference:
https://www.australwright.com.au/technical-data/advice/copper-busbar-rating/
Does since Current requirement is just necessary for the Plus / minus pole were all the power is siphoned from, or do the busbars that connect the parallel cell also have to have this dimensions?
I am just a little unsure wither my general approach here is correct!
Also I have another stupid question...
Lets say I have a 12 V Solararrays and put them into a 12V MPPT solar-charger, could this (albight slower) charge my 24v Battery?
Thank you very much für th time !
Best,
SackofFluor
Best,
SackofFluor
