- Joined
- Aug 30, 2021
- Messages
- 2
I am wondering the applications for this and what to call it so I can search online and learn more about it I was testing two of the exact same motors I found someone threw out electric scooters the wiring was a mess so used jumper cables to hook up a car battery to the pigtails coming off both motors I noticed one had a stiff spot in the chain so I unhooked the negative cable from the battery and started working the wheel around by hand to free up the chain when I noticed the other motor was turning the exact same speed as the one I was physically turning with only the positive cable on the battery my questions are what is this called and second does it drain the battery I am imagining a third motor turning one wheel and forcing the other to do same work may be a use for that in variety of projects including causing downward motion to force upward motion but I don't know what key words to type in to do a proper search
