eRider t9 torque sensor stops detecting torque after ebraking (Phaserunner + GMAC)
cnrd
Hi
I have a problem with my eRider t9, where it will reboot itself, often when I use the ebrake on my GMAC + Phaserunner setup.
It seems like the erider is calibrating when it boots up, so if I apply any pressure to the pedals while braking, the sensor will not detect any torque after braking.
Applying pressure to the pedal while turning on the bike causes the same issue, which is why I'm suspecting the rebooting.
Running the bike without the ebrake attached, I was able to take a long ride, which would normally cause this issue multiple times, without seeing it even once.
The DC-DC 12V is at 12V stable, even when braking.
Rebooting the bike, without touching the pedals will fix the issue until i brake the next time.
Does anyone know what could cause this? And what I could do to fix it?
Hey cnrd, we're discussing what sounds like a really similar problem over here: https://www.endless-sphere.com/forums/viewtopic.php?f=2&t=112368
Would love to hear if you're still having this problem or if you've been able to figure it out.
