Unlocking speed/power limit and searching for a matching lcd display
guyguy14
Hey everyone,
Im trying to unlock my controller's power/speed limit,
Im using a 60v battery, 72v/3kW motor and a 48v/60v/72v 2kW 58A BC controller.
I can reach just about 30 km/h atm, so I'm assuming there is some default limitation on this controller.
I'm using a KT-lcd3 display atm just as an on/off switch,since I don't have a matching display for my controller (which isn't a kt controller).
Is it possible to unlock the power/speed limit without an lcd display connected?
And if not, which lcd display should I get for my controller? anyone knows if the sw900 would work with my controller?
( I don't have a seller to ask because I've got my controller from a friend and didn't find the same one anywhere online...)
so far I've tried connecting a 3speed switch to my controller and it didn't effect the power limit.
Here is my controller label:
0Bgms1B
https://ibb.co/0Bgms1B
Not sure will work with bc controller but did you know lcd 3 has programming options menus are reached holding Down the up and down bottons at same time details of settings found on u tube :mrgreen: peace
