Engine does not run but everything checks fint ?
Yer bike busted? tell us all about it here.
tfvinter   10 µW
10 µW
Post by tfvinter » Jan 17 2022 3:01am
Hey all.
Suddenly my scooter will not run. Everything is checked and is fine.
Controller output is fine on the different wiers. Display is fine. Throttle handle work.
Measured 0.85 volt idle to 3.6 volts on full throttle signal.
Motor sensor all shows from 0 to 5 volts when turning the motor by hand.
Engine clicks somtimes but does not turn. I tried testing with the 3 facewire, hall sensor and throttle only connected to the controller.
The same result. Engine does not run. Tested with 3 different batteries with different volts.
So where should I look for the error? Thanks
calab   100 kW
Re: Engine does not run but everything checks fint ?
Post by calab » Jan 17 2022 3:11am
What is the product you are referring to do you have any links
E-HP   1.21 GW
1.21 GW
Post by E-HP » Jan 17 2022 11:30am
What was happening before it stopped working?
tfvinter   10 µW
10 µW
Post by tfvinter » Jan 17 2022 12:30pm
Nothing happend. Last ride was fine. Next day problem was there.
Chalo   100 GW
Post by Chalo » Jan 17 2022 12:42pm
Try another controller if you have one available. The only reason the motor would be the problem in this case is if it overheated and killed the Hall sensors or shorted the windings.
Also, closely inspect all the plugs and wires. Mysterious failure to run is usually a problem with the wiring.
tfvinter   10 µW
10 µW
Post by tfvinter » Jan 17 2022 5:19pm
thx chalo
