Adrian_
- Joined
- Apr 12, 2022
- Messages
- 84
I was out riding my bike (48v 1000w) and everything was fine and then I stopped at a red light, when I tried to set off, the motor was very loud like it was running without hall sensor and it was lacking power, it felt like 300w. I stopped, checked all connections and everything seemed fine, I did notice that the controller was extremely hot, could not keep my hand on it for more than 2 seconds, not sure if controllers get hot like this, motor was warm aswell but it felt normal. I disconnected the hall sensor to see if it made any difference and the motor started turning in reverse with healthy amount of power as if nothing was wrong (I forgot to plug in the hall sensor couple of times and the motor span forward everytime, this is the first time that it span in reverse without hall sensor). I didn't want to walk home or ride the bike with what it felt like 300w so I disconnected the hall sensor and swapped blue and green phase wires, this caused the motor to turn forward and that's how I got home.
Now the question is, did the controller just get too hot and something inside melted or burned or is it the motor? Without the hall sensor and blue and green phase wires swapped, it rode home just fine except the motor being loud but that's probably due to the hall sensor being unplugged. Wanted to get some opinions just incase it's obvious.
