There are several possibilities, discussed in various TSDZ2 threads, but could include just needing to bed-in gearing/etc., or debris left inside from manufacturing, or cracked bearing races, or clutch/freewheel problems, possibly even a cracked BB spindle at the known-weak-point(s).
Carefully and slowly hand rotating the cranks forwards for whole rotations, then backwards the same, and listening for the noise may help pinpoint it. Certain things will be cyclic in different timings; stuff right on the BB spindle will probably click just onc per rotation, while things involving gearing may click only once per gearing ratio rotation (which will probably be faster than the crank rotation). If it doesn't make a sound with crank rotation, it may make one only during motor operation.
If it's under warranty you're probably best off dealing with the seller on exchange/return/repair/etc., to avoid spending money you don't need to (and voiding future warranty).
Otherwise I'd recommend poking thru the existing info; this is one possible search that might help
https://endless-sphere.com/forums/search.php?st=0&sk=t&sd=d&sr=posts&keywords=tsdz2+%2Aclick%2A+%2Anoise%2A&ch=-1
