hydrinium.h2
- Joined
- Jul 25, 2019
- Messages
- 14
I have a TSDZ2 48v 750w that recently started having issues with the assist completely dropping out whenever I start applying more torque. It feels like the torque sensor is reporting values in reverse, with normal flat cruising working fine but when I start going up a hill or switch to a higher gear the sensor value actually starts going down to zero and then I'm left peddling up a steep hill with 0W assistance. I'm running the open source software, so I checked the diagnostic values while testing the bike and the cadence values seem to be reporting correctly while the torque values decrease when applying more force to the crank. I hadn't noticed any issues before this so I'm a bit stumped what the problem could be. Anyone seen this issue before?
Thanks
Thanks
