Programinator
- Joined
- May 7, 2022
- Messages
- 24
Hello. I installed a 48v horn diecty to the battery with a momentary switch. The battery is 48v. What happens is that in pedal asist mode it will run as normal even when i hit the horn. But if I am just on the throttle and hit the horn at the same time it cuts power to the motor. If i stop the horn and keep the throttle down it does nothing. But if i stop horn release throttle and re-engage the throttle it works like normal. Is there a way to have the horn work without it cutting power when on throttle?
