PAS sporadic dropouts
Is it only with PAS, and not with throttle?
Is it only in one specific assist level, or all of them?
Does it happen the same with a full charge on battery vs less charge or nearly empty?
Working on an "easy stuff first" basis, the first thing I would look at would be the distance between the magnet wheel and the PAS sensor. They should be fairly close together, but not rubbing against each other.
Second would be the the PAS sensor wiring connector
