DonutHands
- Joined
- Jul 3, 2022
- Messages
- 1
TDPRO 48V brushless motor controller. The controller has plug marked 'indicator' which I think is normally used for battery level or just voltage pass through but now its indicating 1v instead of the battery voltage and of course the real problem is the motor isn't turning when I hit the throttle.
This happened once before, but I unplugged some cables replugged and then things just started working again. Since it last worked I have done nothing but park it and charge the battery.
The battery does test @ 54v on its own.
I have my throttle, brake, powerlock, 'stalls'(gears/speeds), 'astern' (fwd/reverse), all connected.
Any ideas whats wrong?
