lookinglikejesus
- Joined
- Mar 14, 2022
- Messages
- 26
Hi,
so recently the positive end of discharge connector on my pack tore and that damaged my controller, which I will replace. I have the ebike tester device (the generic chinese one) and it showed that the coils on the motor are fine, but the halls for the main hall sensor showed two lights stuck and one frozen upon spinning the wheel, indicating bad halls. However, when I plugged the tester into the spare set, the halls were shown to work perfectly.
So what exactly does this entail? From what I understand, there's only one set of halls, and the spare acts as a backup. What exactly is damaged, the harness? The wire? What's the process of replacing it, if there is any, and can I ride with the spare for now?
