What do in need to buy or do to connect the GRIN Frankenrunner to the EM3ev 52V (14S7P) Battery Pack? The battery is terminated with XT90-S, but the cable that came with the Frankenrunner terminates with Anderson Powerpoles.
The least you'd need is a soldering iron and heat shrink tubing (or electrical tape). I'd cut off the Anderson, and strip and solder the conductors to the harness with the Anderson on the other end. Otherwise, you could get an Anderson and crimp it to the conductors of that harness, so you need to get the connector and a crimping tool.
Make sure you unplug the XT90 before doing any soldering or crimping. I get nervous just looking at the picture with it plugged in, even though the positive conductor is mostly insulated.
