Hi. I would like to leave a note on a potential dangerous situation with trottle cables. The trottle ground become broke and the non precense of ground results that the controller send the 5v direct to signal and the controller think you hit max trottle and send full avalible power to motor, so there it drove away without any driver in my backjard. Well it fell after a few meters and the wheel rotaded in air until i disconnect vcc.
It seems like about 7 smaller signal and ground wires has just broke and become lose from circuit board. I did just desolder every wire that have no purpose to me.
But the selflearning wire in one end was loose and was not posibiltie to trace.
But I think it just should go to ground. Is this the usual solution in selflearning circuit one signal to ground to aktivitete.
