Moustachemiks
- Joined
- Jul 12, 2021
- Messages
- 17
Hi all,
So I've went through a lot of thinking in relation to designing my new cargo long john bike. However, I've come to a crossroad (again), where I'd appreciate all the input from experienced builders that I can get.
Info:
Long John cargo bike
Bafang 750W
20" front wheel
26" rear wheel
So, I'm deciding on gears & brakes and have spoken to a few bike mechanics in the process. As of now, I'm torn between getting an internal hubs with roller brakes, an internal hub with disc brakes or external gears with disc brakes. A bike mechanic advised me to get disc brakes, since traveling on a cargo bike with roller brakes will increase my break distance greatly compared to disc brakes. Also, the bafang 750W goes above the legal EU limitation, hence, he thought it might be a good idea to not take any chances in that regard. I agree with this, however, let's list the pros and cons to give you some insight to my thought process.
Pros & Cons from what i've gathered:
Internal hub with rollerbrakes:
Pro:
- Easy maintenance
- Cheapest option
- Can buy a complete rear wheel
Con:
- Brakes are not as powerful as disc brakes.
Internal hub with disc brakes:
Pro:
- Easy maintenance
- Best break potential
Con:
- Expensive and can't buy a complete wheel, hence need someone to build it.
- Cost half of IH with rollerbrakes
External hub with disc brakes:
Pro:
- Cheaper than internal hub with disc brakes.
- Still more powerful than roller brakes.
Con:
- Higher maintenance
- I read a lot of people have issues with chain line and changing gears? i.e. lowering number of gears.
What I'm currently looking at in relation to internal hubs are;
Nexus 8 speed w/ disc: https://bike.shimano.com/en-EU/product/component/nexus-c6000-int8/SG-C6000-8D.html
Nexus 7 speed w/ roller: https://www.bike24.com/p2285613.html
I'm really into the idea of getting disc brakes, but perhaps some of you can tell me it's a bad idea or advise for an alternative - or simply tell me that it's the only right solution
Info:
Bafang 750W
20" front wheel
26" rear wheel
Pro:
- Easy maintenance
- Cheapest option
Con:
Pro:
- Easy maintenance
Con:
Pro:
Con:
