Question about switch behind XT60
Hello all, new here and about to start my first build.
Question - Why not put a toggle switch behind the XT60 battery connector?
I read all the time about sparks plugging in the XT60 and haven't seen any build or mention of installing a toggle to prevent this.
Am I missing something?
Yes, you can do that if the switch has contacts sufficient to handle the inrush current. :thumb:
Related post..
https://endless-sphere.com/forums/viewtopic.php?f=3&t=114882
I think they also sell an XT connector with built in resistor for spark protection?
I did that and used a Marine DC switch for the purpose.
Various Switches: https://endless-sphere.com/forums/viewtopic.php?t=110347
I had XT90's with spark prevention, but they were too big when using 4AH and 6AH packs, so I migrated to XT60's. Now I use XT60's on all my batteries.
Yes, sometimes the connectors darken from all the popping.Except for the few times I wired an XT60 backwards (KAPOW), I've not yet had a connector fail.
The same spark occurs whether it's at the plug or inside a switch. So choose for yourself: do you want to erode a plug or a switch? You might have reasons to prefer one or the other.
Yes, I would rather contain the spark in a switch than have it in the open air. Ultimately it's small potatoes I guess.
