KT LCD8 issue « copy complete »
Alexb92150
Hello I have an issue with my Lcd8h
It says copy complete and I did not try to copy anything
It was a bad manipulation and now I cannot use my bike.
It says copy complete when I click +\- to get in the parameters…
What can I do ?
*What* was "a bad manipulation"?
Did the system ever work correctly?
If so, please describe the complete circumstances leading up to the problem (what specifically happened to it; what did you (or someone else) change, etc).
If it did not ever work, did it have previous problems you have already fixed? If so, what were they? Was it bought used from someone else, etc?
What can I do ?
Hi everyone
It was working fine. I changed C11 in 2 by mistake.
When I let the screen after powering up it brigs me to parameters menu with « data source » in the lower right corner. Impossible to navigate in the parameters. When I press up and down buttons when screen turns on, it says copy complete…
It says in the LCD8H manual that if you leave the "copy complete" alone for at least a minute, the screen returns to normal?
Well, you could bypass the LCD and have the default PAS and throttle, while you wait for a new LCD to arrive.
