Build QS 205 mid-drive diy - sprocket
patrik5504
Hi, I'm building a diy ebike and I need help with a mid-drive motor set-up. I use a vortex frame from the vector company. I want to use the QS 205 3.5t motor, but it is not adapted to mid-drive, it is possible to give it a freewheel, as in the photo. The question is, can I use a single freewheel 16t to use the mid-drive motor? it will work? I would like to use chain 428, did anyone do a similar diy? I would like to be sure that it will work well, or if someone has a link where to get an adapter or sprocket, I would be grateful.
won't there be a problem with the motor overheating? I willing to use this motor as a hub motor in the rear wheel.
<snip>
To know if it will work, or if it will overheat, you need a lot more information. A drawing (even a crude sketch) of how you want to setup your drive, including chain path, would help you and us see how your system needs to work.
What do you want the freewheel to do? It is normally used to keep the wheel from driving the pedals. Since the motor won't be in the wheel, you don't need it for that reason. It can be used to keep the pedals from driving the motor when the motor isn't used, if that's a mode you'll use. If you want to keep the wheel from driving the motor when motor not in use, put the freewheel at the wheel, just like normal.
As a side note: If you have it as a middrive, and you want the motor to spin your chain to the rear wheel on the right side, or to the pedals to then spin the chain, it won't work, because the freewheel will disengage as the motor spins forward and the chain will just sit there. If you flip the motor over the other way, so it drives the left side, then it would engage the chain, and only freewheel when the motor was not spinning fast enough to be faster than the chain being moved by teh wheel. However, the chain would then always be moving if the wheel is moving, and you would need a guard to prevent you or other things getting into the chain.
For the number of teeth: The 3.5t motor will spin really fast (vs a higher number of turns). a smaller front sprocket (like a 16T) vs a larger rear sprocket will convert that speed into torque. If you want to keep the higher speed, you need the same size or smaller sprocket at the rear. Smaller than 16T at the rear is hard on the chain and sprockets, and may skip under high loads, so it's better to use larger sprockets on both ends. Without knowing your intent and system setup, can't suggest actual sprocket sizes to use.
You'd need to know what your specific riding conditions will be, your terrain (slope of hills, etc), wind, road conditions, riding style, speed, weight of everything and you together, along with the intended controller and battery, as well as the gearing from the motor to the road and the wheel size, to see if the load on the motor and the power supplied to it would be greater than it's ability to handle.
You can see how this works in the http://ebikes.ca/tools/simulator.html
okay thank you, it looks like it's going to be more complicated than it looked. Yes, I wanted the motor sprocket (freewheel 16t) to drive the rear wheel through the chain (428). I would attach a sprocket to the rear wheel, for example a 50t gear. Would I have to replace an entire motor that has a sprocket which would drive the rear wheel?
I'll probably stay on the hub-motor, I saw a few people that had it on a vortex frame. I wanted a similar way to ebike vortex, but I don't have a 7200$ budget with tax.
G'day Patrik.
Here's an idea I used on my chopper, using a hub motor as a mid drive;
The sprocket nearest to the motor is a fixy sprocket, thinned to allow enough thread for the freewheel to screw on & runs to the back wheel. The freewheel has the chain from the pedals
With the motor driving the fixy sprocket, it wants to undo but the freewheel acts as a locknut.
Works for me, it might for you.
AussieRider
