scrolltonowhere
- Joined
- Mar 30, 2022
- Messages
- 76
Ok so I tore this bike apart and rebuilt it into an e-bike. I knew very little of bike maintenance before doing this.
I upgraded to Shimano V-brakes from the previous middle pull cantilever brakes and I have Jagwire brake and shift cable housing. So first of all, the previously the brakes and shifter cables housing didn't run continuously - exposing the bare wire between the cable stops. So first of all, I'm assuming I should run the brakes the same way is before, or is there any advantage for running continuous housing?
Secondly, the bottom bracket was replaced by the mid-drive electric motor. The shifter cable previously was run underneath this. There is now no space underneath to route this cable housing. So now is it possible for the bike tho shift normally if I run a continuous shifter housing all the way to my rear derailleur? If not, how would you approach this? Also, should I put a lubricant in the housing?
As a reference, this is a Trek Multi-track 730.
Should the shift cable housing just run parallel to the chainstay and just run it along the downtube?
