The Toecutter
- Joined
- Feb 8, 2015
- Messages
- 1,312
I got the brakes stopping as they should and shifter working as it should.
I still prefer riding the Milan, but at least I have the KMX for when I know I'm going to have to go across bad roads. I always had to take detours around my normal routes with the Milan, and it's gotten banged up a bit on the underside, although it's hard to say how much of that was from the two hit and run drivers, including the Karen bitch in a white SUV who deliberately rear ended me and flipped it at 30 mph after tailgaiting me for many blocks(after inspecting the damage in the rear, I'm certain she hit me).
I don't know when I'll get enough time off of work to actually overhaul everything on the KMX the way I intend. I have $2,000 of parts laying around for it waiting to be installed. Still need to spot weld my new battery together as well.
Then comes the arduous task of translating my body shell design to reality. A friend of mine has a 3D printer that can do cubic meters, and he's almost got it calibrated properly. I intend to print the new body shell in pieces out of plastic, then wrap it in fiberglass with innegra. There will be a removable nose and tail mounted to a midsection that is slipped directly over the frame.
I also need to re-engineer those steering spindles. Thanks to uPET, I now have spares.
I'm building a scaled-up Milan with ~6" ground clearance, 39" front track, exposed front wheels flush with the airflow over the body, roll cage, and with clearances appropriate for 2.25" DOT tires as well as a rack and pinion steering system. The goal is 225-250W to hold 30 mph.
If it works well, I'll eventually try to build a monocoque of the design and ditch the KMX frame altogether(I'll still keep whatever bike I build out of the KMX). Then build an overpowered AWD electric car out of it.
To think, a little bit over a year ago, I was washing dishes at the local COVID den. My resume had been languishing around for 3 years and I could scarcely get an interview, and now my current employer at an engineering firm wants me to do way too much work because I'm good at it. Still not putting my greatest talents to use though. "Capitalism", eh?
