I had 60 cells of used Panasonic 18650pd 10amp/2900mah, I got them off my battery guy for cheap so I yanked the nickel strip off, long story short they were 4.18v about 6 months ago last week I checked them and 52 were all 4.09v but 1 cell was showing electrolysis on one of the spotwelds where the nickel strip had been, so garbage. 51 cells, 17s3p is 51 cells, I decided to make a backpack battery.
17s3p of 18650pd is 30 amps and 8.7ah and weighs 7lbs
I paralleled to my 25r4p pack charging connection and I used a 10 amp fuse in between the bike battery and backpack battery
when using different battery types there can be issues with resistance so I started with a 10 amp fuse and wanted to see when it would blow.
phaserunner was set at 2500 watts the batteries were at 69. went outside thinking id blow the fuse right away but no. I was pulling 2200 watts up a hill, pull over and check the ca max amps were 36 amps. 7p at 36a is 5amps per cell, that should blow the 10amp fuse. I rode the bike hard for 15km trying to blow the fuse but couldn't. went home unplugged the packs and tested the pack voltages. 25r was 0.5v lower than the Panasonics (the Panasonics appear to have the higher resistance) plugged the packs backtogether. changed the phaserunner to 3500watts had a coffee, checked the batteries and they were 0.1v apart.
another test run, blew the 10 amp fuse right away at about 2700 watts so I replaced it with a 15 amp fuse to see if I could blow it but I couldn't. my battery was about 60v, the ca was showing 2700 watts but it said my amps were at 50. im not going to up my amps for a test when I can just charge my battery. I only went about 1km uphill trying to blow the fuse and when I got off the bike I checked the voltages and the packs were 60.2v for the 25r and 60.9v for the pd so I just plugged them back together to balance them.
at 2700 watts my packs drifted apart by 0.7v after a quick/hard km ride, couldn't blow a 15amp fuse, theres going to be issues if riding hard
at 2200 watts my packs only drifted 0.5v apart, I couldn't blow a 10 amp fuse and 15km of hard riding, seems perfectly fine
conclusion
at 2500 watts and 10 amp fuse, no problems, ride like a madman. 2700 watts of hard riding you might start blowing 15 amp fuses as the pack voltages drift apart. the pd is higher resistance so its volts will be higher and will behave like a battery charger. a 25r can receive 4amps for fast charging. 4p of 25r is 16amps of fast charging so if the 25r tries to suck more than 15 amps from the pd pack the fuse will blow. ill have to see what happens at the lower voltages though. suppose to snow tomorrow so ill add more info when I can test again.
also if anyone is following this thread about volt sag and what batteries I might use, I was basically running a 7p pack today and my volt sag didn't change 4/5v so if I want less sag the problem isn't the battery I could probably beef up my wiring to lower resistance. been reading some threads, I wouldn't use a 30q, im looking at 40t and 50E at 4p. if you look at the numbers im sharing. the bike at 2200 watts 36amps and 70v is a fun bike. 4p of 50e is 20ah and 40 amps and should have atleast twice the cycle life than a 40t 4p 16ah.
