Voilamart stealth bomber clone
NEOsloppy
10 µW
So I ordered this yesterday and got it today. Super fast shipping. No rubber bushing for swing arm. A bronze bushing. Should fairly easy to remove.
Will be a slow build. I just started on my first ebike. And already ordered this so probably sleeping on couch tonight.
What’s best way to add pictures?
I assume you mean pics you took yourself. So when you have the reply window open, you can click on the 'attachments' tab and get the 'Add files' button. You have the option to place it inline so it's seen in the post without clicking for a download, there's a data limit and I don't recall what size it is.
[attac hment=0]PostPic.jpg[/attachment]
Hey I just got the same frame from Voilamart. Subbed
https://drive.google.com/file/d/18iolb1pe5B4w4EIdRTYzaLTaLR-C38Fu/view?usp=sharing
Just starting to get mine together
https://endless-sphere.com/forums/viewtopic.php?f=2&t=109479
Easy build with QS205 4T, 150a controller @ 84V and away you go :D
This one was made from bits in the parts bin so please excuse the 24" mtb front wheel
Mods: Headstock bearing . lower seat bracket if you're under 6 foot five :lol:
Jonno
My thought is that it's like an old Camaro with a PUMPED motor. Sure, it's totally fine because the power of the motor will overcome the "tank" weight of the car but... what if the car was lighter? Better handling. Better braking. Better stability and control. And it'd be FASTER and more efficient.
Before I assemble mine I'm taking down every measurement in case I decide to fab (or have fabbed) an aluminum clone.
Why not build on a Downhill MTB?
Some good inspiration in this thread: https://endless-sphere.com/forums/viewtopic.php?f=6&t=235&start=1850
Or build a copy of a LMX64:https://endless-sphere.com/forums/viewtopic.php?f=28&t=96809
I am building what could be kinda considered a downhill mtb. The thing is, I NEED a frame that doubles as a battery box because I just got another 200 Tesla cells and plan on using all of them.
Hello I have this exact frame I had a question on the dropout I'm using a 205 motor and the dropout is itoo wide I don't know if any of you had the same problem I could just use spacers but it makes the use of the torque arms that the motor came with difficult. I've heard of people stretching this swing arm when it was too narrow I thought about just bolting it up it's about 7 mm per side.
I just packed it out using some washers :wink:
Jonno
