I’ve got a 3G bikes Newport Deluxe, aluminum frame with 26x3.45” tires, that I’m in the planning stages of converting to an e-bike. My goal is to ride this around the beach as much as possible. 20mph speed limit, but I’d like to get there reasonably quick, with a range of 25-35 miles.
The first challenge that I have is that this bike just has a a rear coaster brake. I’ve ordered parts that will hopefully allow me to put a disc brake on the front. Once that is sorted out, I’ll order the motor and batteries. I’m hoping to get a motor/controller combo that will do regen braking and allows the option of setting up a rear disc brake.
So far I’m looking at the following parts list and would like your feedback on this list if you don’t mind. I’ve got a bunch of questions below. These are really questions that I need to research answers for. I’m mainly looking to see if you guys spot any obvious mistakes or headaches that I’m about to get into.
Q128H-135, 48v 800w motor
The bike is aluminum and has a 128mm bolt-in rear. I understand that I could stretch the frame or this motor can be reconfigured for a 120mm freewheel setup, where I could use spacers to place it properly in the frame. A freewheel allows for a single speed or a multiple speeds? I would try to build a disc brake setup with this motor, if I can fit a brake caliper to the frame. The bike isn’t setup for a derailleur and shifter so I would leave it as a single speed at first. I suspect that I will want to upgrade later though.
S12SN 1000w, 40A controller
This controller used with the above motor should allow me to reach my speed/power goals, and also allow me room to grow if I want to add power later. Also, I believe it supports regen braking in case I need to rely on that as a rear brake (I’d prefer a disc brake for safety reasons). Does the regen act as just an on/off function, or can it be linear with brake lever setup? Will the controller allow me to set a speed limit, instead of a power limit? (I don’t believe the seating position on this bike is conducive for high speeds)
48V10AH/14AH CASE-08 BOTTLE BATTERY PACK
This has an optional “inner controller”. From what I’ve seen, I don’t think this controller will allow me to reach my goals, so I will not select that option. I need to take measurements to see if this will fit in the frame.
S-LCD8 screen
Thumb throttle
I’m used to riding ATVs and think I would prefer this over a twist throttle. Although it could get in the way if I switch to rear gears in the future.
PAS
I will plan on adding this as a future revision.
I also need to figure out how to install the motor in the wide 26” wheel. I guess step one is measuring to figure out how long the spokes need to be. It’s probably easier to just take it to a bike shop, but I’d like to learn this process anyway. It seems like a useful skill and my son is really getting into biking.
Well, that’s all for now. I’ll post pics of the bike once I put it back together. It’s in parts right now while I was taking measurements and trying to figure out a reasonable path forward with this project.
S-LCD8 screen
Thumb throttle
PAS
