APL
- Joined
- Aug 6, 2018
- Messages
- 1,113
Oh boy, a new build! Hopefully I won't belly flop on this one, but you never know, I've been pretty good at that lately.
I came across several 13s/10p - 26ah batteries a while back, and it's either use 'em or lose 'em, so I need a new frame to
put these big boys in.
I decided to go with a four tube girder frame this time, since it's more 'square battery' friendly, and I don't want to have
to reconfigure the battery packs. Trying to make a big square hole in a bike frame look good is near impossible though,
so she's not much of a looker. This is what happens when you send marketing home, and let the engineers have their way.
I've never built a small tube girder frame before, so who knows how this will turn out, I guess we shall see,...
OK, so lets get started, five 6' lengths of 3/4" .049" 4130, a 1-1/2" piece of .080" head tube, and a slab of 1/4" soft steel.
About $150. worth of frame ectoplasm.
First, I did a rough sketch in CAD, and once I had things moved around the way I wanted, I transferred the sketch to a full
sized drawing that I will use in the shop. The drawing allows me to place the tubes on and make sure that I have the bends
right, triangulate measurements, and I can also place actual bike parts on it and make changes on the fly.
CAD drawings don't really do me much good in the shop, although some prefer to build that way, I prefer full size, in pencil.
The batteries and the motor are about the same 10" size, so I put them together and slung it all down as lows I could.
Since the motor is going to be in the line of fire, I surrounded it with a bash cage 'ring', and helps to frame, or feature
the motor.
So this frame starts with a head tube and a pair of dropouts. Add the two top tubes, and the two down tubes, and bingo,
we have a frame. Everything else is just braces and brackets.
the motor.
