Time to resume ebike builds for the FL "winter"
Picked this up last season for 40 bucks. If there's a bicycle out there begging to be amped up this is it. The Teutels being chopper builders and all...
Will be bolting on another MY1020 inrunner rated for 72V and will be sharing the 20s5p MJ1's custom battery pack I built previously for my Mongoose Girder build. The ebay motor came with a standard issue Chinese controller rated at 65A, which is nominally +10 over the other build so should be a few more max watts. I have about 1000 miles on the "Girder" build, and am very pleased with the performance of these components, and you can't beat the price. The only caveat is to wire up the 3 speed switch they're designed for to smooth out the otherwise sharp hit from standing starts- it's an electric transmission... The Girder maxes @ 45mph with a light tailwind with 13/80 sprockets; this build should hit close to 50mph with 12/80 due to the extra amps and larger diameter rear tire. 25H chain works fine. Just be damn sure you use Razor chain guide plates on your rear sprocket. Speaking from experience.
I welded up an aluminum bracket that will hang the motor under the frame just in front of the rear tire. Still finishing that setup. The battery pack sits on top of the flat lower frame member and the controller will U-bolt in front of the downtube. Fixed footpegs will attach non-destructively through the bottom bracket. No pedals. Will fabricate a lexan tractor style seat to replace the uncomfortable stock chopper saddle. Moving the rear V brake bosses from lower to upper stays for chain clearance. Then it's just paint and wiring...
