Hey guys!
https://www.specialized.com/us/en/stumpjumper-pro-29-6fattie/p/129072?color=240009-129072&fbclid=IwAR2MFMudfJjGy7M0UF5iethz4EIF4Od57pfz-hybNjrjV7LkboMoOz7N8bU
I just got a Stumpjumper PRO 2018 fattie 29/6 that im thinking about going electric with. Its not a great bike to do electric, at least not with bafang but i got a really nice deal. I have to go backpack battery. I got a guy that specially orders BB02S 250w motors with 900w nominal and only slightly less powerful than a 750w and more efficient but since the frame is such that it needs to hang more or less straight down im a bit worried about the clearance. Maybe i should go with a inside frame motor like this instead https://www.lift-mtb.com/accueil-faq-english/motor-inside-or-outside/ Does anyone have any experience with either?
Also the bike has a PF30 BB so i assume i will need a https://lekkie.tech/product/lekkie-pf30-bafang-adapter/ ? Could i just 3d print this? Would PLA be strong enough over time? Its quite hard when you oversize a bit and press things in but with the added on off it could get loose over time
Any other items that are good? I might not always want the battery either so perhaps a 40 tooth Lekkie ring? i believe it has a 30T on there now.
Any help starting up and making it as easy as possible is great, Im tech and practically minded though
