RunForTheHills said:This bike? Aside from the issue with the single gear, have you thought about where you would mount a battery on the bike? You don't need a large battery for 9-10 miles round trip, maybe you could put the battery in a saddle bag hanging off of the seat. Anything else you are carrying to and from work would have to be in a backpack.
E-HP said:When I was looking into it, I was looking for a long top tube steel frame, with 1 1/8" head tube, and very little triangle. The plan was to replace the fork with a 110mm front suspension fork, which would relax the head angle (and maybe make the bike more stable, instead of twitchy, at higher speeds), but also allow me to mount a Hailong pack under the downtube. The frames I've seen that meet those specs are expensive, so just casually keeping an eye out. The other option was 24" BMX, which also seem to cost a lot. I also thought of using a 100mm front hub in the rear, and changing the side cover to allow a single speed freewheel to be added to it.
Fvrdol said:I am 1,75 cm so i fit in my bmx bike 20" with banana seat. And i am 80kg
I am starting to put batteries under banana seat it has enough place.
The question which i do not understand is which motor will be best to fit to 20" bike
Fvrdol said:Hello to all,i need help . I would like to convert my bmx 20" to electric. So i need any advice from you.
A loot of questions is in my mind like single gear bike,whatto put hub or mid drive .... Do i need single cog.... What w i need ...please help
Fvrdol said:Then i need rear hum motor kit with 110mm at rear o.l.d.
If anyome has idea where to find thst kit please replay
Fvrdol said:I am open for every advices... Nice idea front wheel.. so i need go buy hub motor with single speed?
Whole afternoon i was searching fromt hub motor 20" for single speed and i lost my eyes without suxcess
In my country we have a loot uphill and downhill so can you tell me how front wheell did on uphill?
