Show off your Ebike creation here.
Johne-bike   10 W
Re: Your Creation's Before & After Pics
Post by Johne-bike » Feb 11 2018 2:49pm
Hi Buk_
Thanks for liking!
In fact, that right side picture actual shows the box that contains all the wiring connectors from the KT Controller, which is fitted adjacent to it on the left side!
The Connector box is actually a large hardshell sunglasses box, covered in Carbon fibre vinyl wrap, and does a perfect job of concealing the connectors, and fits great in the space, backing onto the controller.
I have posted a few more pics of the bike as it currently is. Next on the list enhancements is to fit a Suntour NCX suspension seat post and upgrade the front brake to a 203mm rotor with better brake pads.
KT Controller left side
Wiring connectors enclosure right side
KT Controller and KT-D12L PAS sensor
Speaker enclosure
Rear carrier, seat and Roswheel bags..
Cockpit view
Bluetooth amp and speaker installation
free-trade   10 mW
Post by free-trade » Feb 16 2018 5:21pm
Where do you get that carbon fibre vinyl wrap? I used black tape for some shiny parts that I could not get in the right color, but i like your solution better...I wish I would have the time to visit thailand again
Johne-bike   10 W
Post by Johne-bike » Feb 16 2018 11:43pm
free-trade wrote:
Feb 16 2018 5:21pm
Hi, I purchased all my Carbon fibre 3D vinyl wrap from a vendor on the shopping site Lazada, which is an online site very popular in Thailand, and now owned by Alibaba. There are loads of stores on Aliexpress and Ebay offering similar products.. Just do a search online.
Carbon fibre vinyl wrap is really easy to use and adheres well to many surfaces and us easy to stretch around curves if you apply some heat with a normal hair dryer. It looks great, and all the parts I have covered are around 12 months old now, and show no signs of deterioration or edges lifting etc. It's a really great DIY finishing material!
luckyozone7   10 µW
10 µW
Post by luckyozone7 » Feb 22 2018 5:24pm
Alright everyone, this is my first post and i guess the right place to begin. This is actually my second build, my first build was in 2010. Ebike scene has a lot more resources then it did back then...
Before...
and after.
I use it to get around town and because the battery case is sealed its pretty safe, I don"t really worry if someone is going to steal the battery when i park at the store. It has a 2 mode 48v 1000w hub and controller with a 52v 16.8 ah battery that does 30 + miles of distance safely in street legal mode up to 20mph and 35mph (probably a bit quicker) in off road mode but really isn't easy do to traffic, you really have to be alert to ride that fast...
hodala   100 W
Post by hodala » Feb 22 2018 7:00pm
before after
fat tyre 20.JPG (95.86 KiB) Viewed 6040 times
zro-1   1 kW
Post by zro-1 » Feb 23 2018 9:50pm
Before:
After:
The build thread
~01~
CUDAcores89   1 W
Post by CUDAcores89 » Mar 03 2018 4:30am
here's mine:
Before:
After:
Specs:
Motor: 36v "500w" rear wheel hub motor, one of those ebay kits. Works great for flat roads and commuting, which is primarily what this bike will be used for. I am running the controller with a 14S 20AH A123 systems battery for the extra volts without the speed of 48v. Using my watt meter, the bike uses around 1KW when i'm riding around.
The other reason I went with a 14S lifepo4 setup is because I have other chargers meant for li-ion batteries that are 12S. a 50.4v voltage cuoff seems to be one of those really magical numbers when it comes to lithium packs because:
1. A 12S lipo/18650 pack charges up to 50.4v.
2. A 14S lifepo4 pack charges up to 50.4v.
Try going higher or lower than than 50.4v, and you now require bulk chargers with a different cutoff voltage.
Now I can reuse my current bulk charger on any potential li-ion battery packs that I build in the future and use them on my lifepo4 pack as well.
Battery: Battery is a 14S1P pack made from A123 systems 20AH lifepo4 cells. The battery is currently pulled from the bike in this image, but I have to split the battery up into two physical pieces. One goes in a bag on the rear rack and the other in the triangle bag.
Bike: It's a 2006 gary fisher wahoo mountain bike. Nice chromoly frame for virgidity.
No battery murdering system for me, i've never had good luck using them. I constructed my battery with some low-voltage battery buzzers and fuses to protect from over-current and under-voltage during discharge. For charging, I use a ming-HE BST900W + 2 server power supplies for bulk charging and an icharger 208B for balance charging.
Bike will be used in Michigan weather, so I started by using some specialty "waterproof tape" meant to seal pipe leaks. After I ran out of the tape, I had to go back to using duct tape. I just REALLY don't want water getting into my bike parts. I've destroyed controllers that are theoretically "sealed" from water getting into them.
If you didn't clue in yet, this is a commuter bike. I ride 5 miles to and from where I work every day, and use this bike to do it.
Next upgrade for this bike will be front disc brakes. The nice thing is this bike already has the eyelets on it to install disc brakes. I'll have to buy a new front tire but hey, I have somewhere to start.
The Mighty Volt   10 MW
Post by The Mighty Volt » Mar 24 2018 7:05pm
Before....lol that was just a black frame.
After.......so much better!
Motor: MAC 12t in a 24" Rim with Hookworms
Controller: 6 FET 4110 Cellman
Battery: 8000mah Multistar 16s
Jnold7   1 µW
Post by Jnold7 » Apr 02 2018 6:55pm
Goal was to create a (somewhat) stealthy commuter bike that could break 30mph when i felt the urge to. The "before" is my commuter bike from college...i used to be cool and could ride fixed gear on the flat roads of Ft. Collins, but have afterward changed over to the freewheel. (30MPH in fixed gear makes for a steep gear ratio or very fast feet :? ). Nice 4130 frame with solid front fork dropouts. https://www.statebicycle.com/collection ... te-black-6
The components came from http://www.ebikes.ca/shop/electric-bicy ... basic.html
-9C 2706 hub motor on a 700C Alex rim
-35amp sinewave controller
-regen brake
-"T" thumb throttle
The battery is a beast of my own creation. Essentially dismantles qty 6 "20v" 4ah Dewalt Chinese knockoffs assembled into a 18560 15S 4P configuration arranged to accept fully balanced charging from the 8amp 4.1V dewalt charger (approx 4 hr total charge time).
The advantages of this are fairly obvious (cost effective ($200 for 56V 8ah) and supposedly long lasting)...the one disadvantage is that you have to change the charging plug 3 times to achieve a full charge (1 charge cycle per 5s stack). https://www.amazon.com/FirstPower-Repla ... FIRSTPOWER The other nice feature is that the batteries come pre-spotwelded with nice solder tabs on them.
Nice and simple cockpit
Vortecks   100 mW
Post by Vortecks » Apr 15 2018 9:35pm
My 'before' and 'after'
https://www.youtube.com/playlist?list=P ... lj0LHdCG7S
I wanted to keep it looking like a normal bike but I got a little carried away :lol:
amberwolf   100 GW
Post by amberwolf » Apr 21 2018 2:48am
Some pics of an alternate configuration, with a seat mounted in the cargo area, to take my brother places (or help coworkers get home after we close, etc). Also shows some of the woodwork changes, etc:
viewtopic.php?f=2&t=67833&p=1374276#p1371158
CATAWEB   100 µW
100 µW
Post by CATAWEB » May 02 2018 5:23am
THE MIND AND THE MADNESS IS EQUAL
Davescustom   1 mW
Post by Davescustom » May 05 2018 1:10pm
Before:
After:
Tread here
DaDo.Bzz   100 W
Post by DaDo.Bzz » May 05 2018 7:45pm
Vortecks wrote:
Apr 15 2018 9:35pm
Mate, it is nice build, but u need a rigid frame for such a power!
LMX 81, 16S6P 60A
Dengfu E10, M600, 840Wh, 48V
CTM Scroll, BBSHD, 700Wh, 52V
Slovakia, Bratislava
chefkendra   1 mW
Post by chefkendra » May 10 2018 7:46am
Davescustom wrote:
May 05 2018 1:10pm
Very, very nice.
Women who build cool stuff...ROCK!
soaresdacosta   1 kW
Post by soaresdacosta » May 13 2018 8:09pm
My second adventure on the e-bike world of DYE conversion. A lot of time...really a lot.
It was just a frame...an empty frame...
HotRodHocke   1 µW
Post by HotRodHocke » May 22 2018 3:25pm
Nothing spectacular, but here's my Scott Aspect 29er when I just bought it in 2016:
Had to add fenders as I started to use it as a a daily commuter to work:
Bought and installed a BBS02 kit from em3ev.com, very happy with the resulting performance:
As of today with new lighter fenders, lights, new "street tires" and a homemade battery box to hide some of the wiring:
oger   10 µW
10 µW
Post by oger » Jun 22 2018 5:39pm
Cube AMS.
Wanted to have a fully.
Here it is.
motomech   1.21 GW
1.21 GW
Post by motomech » Jul 04 2018 9:42am
Doesn't the rear tire/fender hit the rack?
'11 Motobecane Fathom team, Bafang SWX02-13T, 14S (54V) LiPoly, 9-FET 17A controller. Schwalbe Marathon's, 24 to 25 MPH.
Hobie Passport Kayak w/ Watersnake 18# motor, 12S LiPoly (46V) to golf cart 12V converter, 4 mph
snorkelgnu   100 µW
100 µW
Post by snorkelgnu » Jul 10 2018 8:10pm
Before
After
Battery, controller, and display mounted in bag
Details here: viewtopic.php?f=3&t=95176
Wolfeman   1 kW
Post by Wolfeman » Jul 13 2018 3:24pm
Before
After
Trek 4300 w/ H3580 Crystalyte at 3600W
viewtopic.php?f=3&t=82738
Dyno Moto 7 BMX Cruiser w/BBS02
viewtopic.php?f=6&p=1467001#p1467001
GT Palomar Vintage hardtail w/BBS02
viewtopic.php?f=6&t=104255
Electra Cruiser 1 Tall w/BBS02
viewtopic.php?f=6&t=112437
macribs   1.21 GW
1.21 GW
Post by macribs » Jul 13 2018 5:11pm
Easier to view the pics if they are properly displayed on the forum without needing to go to external site.
Code: Select all
[url=https://ibb.co/cAyiNT][img]https://thumb.ibb.co/cAyiNT/IMG_20180712_155431.jpg[/img][/url]
Code: Select all
[url=https://ibb.co/eEBRbo][img]https://thumb.ibb.co/eEBRbo/IMG_20180712_155347.jpg[/img][/url]
These tags renders this output:
vagosofron   100 W
Post by vagosofron » Jul 14 2018 7:37am
macribs wrote:
Jul 13 2018 5:11pm
Code: Select all
Code: Select all
I'm really sorry for that. Feel free to clean this mess, even this post of mine 😊
dequinox   10 kW
Post by dequinox » Jul 16 2018 3:09pm
Not sure if I posted this here before, tried to check but couldn't find anything. I built this about a year or so ago for my wife. The theme was KISS.
On a dusty pew in a vestibule sits the Devil playing pocket pool, he's waiting for the next poor fool who forgot that it was Sunday
STABLE:
HI-V (Retired); Sun Cruiser w/ Hill Topper Kit; Giant Simple Cruiser w/ Amazon 1000W Front Hub.
Parts donated by Rassy and Greenerwheels have made many of my builds possible, THANK YOU!!!
