Show off your Ebike creation here.
litespeed 1 MW
Post
by litespeed » Dec 16 2021 10:40pm
Since your a street rider I’d tell you to get the 3.5T and put it in a 17” rim like I have with ferrofluid and Hubsinks. You will never heat it up and if you go with a Nucular 24F you’ll be hitting 65 mph before feild weakening if your battery will put out enough watts. Mine does!
The 5T won’t like extended higher speed runs without getting hot. You will not want your Buddy’s to see your motor sweat!
Tom
1abv 1 MW
Post
by 1abv » Dec 17 2021 10:17pm
Is there anywhere that has a list of how much motors weigh?
1abv 1 MW
Post
by 1abv » Dec 17 2021 11:31pm
Mxus 3k - 20.2 lbs
Mxus 5k - 28 lbs
cromotor v2 6k - 24 lbs
Clyte 5403 - 4k? 33 lbs
Qs205 - 3k? 28.4 lbs
Let me know if this seems right to you peeps.
Fixed!
1abv on Dec 23 2021 1:54pm, edited 2 times in total.
Chalo 100 GW
Post
by Chalo » Dec 17 2021 11:46pm
1abv wrote: ↑Dec 17 2021 11:31pm
Clyte 5304 - 4k? 33 lbs
That can't be right. My front X5305 weighs 22-1/4 lbs before lacing it to anything.
1abv 1 MW
Post
by 1abv » Dec 18 2021 2:44am
I got all that from the ever accurate internets..
The cyltes website:
"- 5403 motor phase wire : dia. 4mm 2 x 3 pcs
- Weight : 15kg / ea bare motor"
but who knows...
I haven't weighed mine but with the complete wheel and tire its gotta be at least 45lbs.
Allex 10 GW
Post
by Allex » Dec 18 2021 8:45am
1abv wrote: ↑Dec 14 2021 10:24pm
So im guessing that the 3000 will have more torque but may get hotter quicker which could be about the same as far as heat control that I have now. But If I want to run 8K peak around 4k constant can this motor handle that? I noticed that the phase wire gauge is thinner than the Clyte and can not physically fit 10awg wire Is that an issue?
thanks!
Alex
Trails are for wusses
It will get hot quicker but also cool down quicker. A prefer one that cools down quicker and save the weight just because you can always use ferro to coolt it down. So if you run xmsus 3k and 5403 with ferro, both will have the same good heat management but with the later you will just carry a bunch of dead weight with you...for what?
I always try to shave of the weight and personally would never go with anything like cro or mxus 5k because of just that - the weight.
If one does high speed cruises on the paved roads for miles, then yeah, I would start looking into cro and similar motors.
Theodore Voltaire 10 GW
Post
by Theodore Voltaire » Dec 18 2021 12:15pm
1abv wrote: ↑Dec 18 2021 2:44am
The cyltes website:
but who knows...
My 5403 phase wires are 3.4mm including insulation. I'm guessing 10g.
1abv 1 MW
Post
by 1abv » Dec 18 2021 10:19pm
TV you got lucky! mine were 12AWG and I had to replace the whole shebang. Especially because of the coating they used. Mine flaked away and turned to dust.
AAAAQQQ 10 mW
AAAAQQQ 10 mW
Post
by AAAAQQQ » Dec 19 2021 12:34am
Also.. oh boy its been a bit of an adventure cleaning and fixing this thing up. Red loctite on so many bolts and this spacer... was on the wrong way Im guessing.
- 20211218_150814.jpg (2.52 MiB) Viewed 672 times
- 20211218_150824.jpg (2.29 MiB) Viewed 672 times
AAAAQQQ 10 mW
Post
by AAAAQQQ » Dec 19 2021 12:45am
Last couple of pics. Just wanted to know if you guys with better eyes and brains than me can spot anything out of the ordinary or needs to be addressed. Did the silicone thing between the caps and board, hopefully that takes care of vibration issue.
- 20211219_134017.jpg (2.18 MiB) Viewed 671 times
- 20211219_134108.jpg (4.02 MiB) Viewed 671 times
1abv 1 MW
Post
by 1abv » Dec 19 2021 1:06am
Its interesting to see the insides of other peoples boards. Each one has differences. your caps are mounted vertical where are all of mine are mounted horizontal, My shunt is in a slightly different place as well. Each board feels bespoke.
1abv 1 MW
Post
by 1abv » Dec 22 2021 12:12am
This is what happens when you dont put rtv on the caps...
1abv 1 MW
Post
by 1abv » Dec 22 2021 11:52am
You can kinda see it but there is a killer never-ending single track in the background.. Getting up the hill.. that's the bitch.
Rix 100 GW
Post
by Rix » Dec 23 2021 11:32am
Chalo wrote: ↑Dec 17 2021 11:46pm
Also, don't confuse the Clyte 5304 with the 5403, the 5403 several pounds heavier than the 5304.
1abv 1 MW
Post
by 1abv » Dec 23 2021 1:55pm
Yes typo in the original posting. Just fixed it!
cheeko 100 W
Post
by cheeko » Dec 23 2021 5:00pm
Guys
Thought this is cool Australian Army will introduce Stealth ebikes
https://youtu.be/_-L5NywFoX4
Now Stealth will have cash to go to next level great Australian company
20S7P Futr Beta 26" Mxus3k with the Unbelievable Nucular 12F
Rix 100 GW
Post
by Rix » Dec 23 2021 8:41pm
cheeko wrote: ↑Dec 23 2021 5:00pm
Guys
Thats a good promotion video for sure. We will see what happens there.
AAAAQQQ 10 mW
Post
by AAAAQQQ » Dec 23 2021 10:47pm
What exactly does a trial entail? Did they get the contract? Because I there was another vid released not too long ago with the SF guys testing the Sur-ron.
No kidding though, checking the date and its only 2months ago. Could've sworn it was a year or so.
Getting the name out there and promotional material nevertheless.
Jed_McKenna 1 µW
Post
by Jed_McKenna » Dec 26 2021 12:23am
ex-bomber owner here anyone selling a P7R in melb?
You think i could dirt jump that? i imagine no one has really tried but given you knowledge of physics and the fact i weight 110kgs is it possible? im possibly crazy. and yes i used to dirt jump mountain hardtails as a kid
1abv 1 MW
Post
by 1abv » Dec 26 2021 9:35pm
Evergreens... Cause its Christmas don't you know...
Post
by Theodore Voltaire » Dec 27 2021 12:36pm
Theodore Voltaire wrote: ↑Nov 05 2021 2:14pm
Here's a sad sight. This is my new, new tire. This didn't even take a week. Luckily I discovered this in the garage.
No leaking now for over a month and a half.
- 20211103_123130.jpg (852.89 KiB) Viewed 418 times
1abv 1 MW
Post
by 1abv » Dec 27 2021 2:20pm
Your pierced tire is so punk rock.
cheeko 100 W
Post
by cheeko » Dec 27 2021 4:30pm
Rix wrote: ↑Dec 23 2021 8:41pm
Guys
I don't think Army saying brand but we all know lol but massive case injection for them.
Peter
