Chopper with Cyclone kit
commanda   100 W
Post by commanda » Jul 05 2008 12:20am
So I bought this chopper off eBay for $80.00. Unwanted Xmas present with very little use. Ordered a Cyclone 180watt kit direct from Taiwan. The battery mount is thin plywood, held on with cable ties, and not painted yet. The 2 x 12volt 7AHr SLA's I already had. Didn't use the Cyclone crank axle, as this bike's axle is already longer. Took it for a quick blast up the street, ran fine.
Problems at this stage:
1: the freewheel crank slides on too far, and fouls against the bearing cup. I shimmed the square taper with some heatshrink for now, just to get it going. But this will require further engineering to get it right. Possibly some very thin brass shim material.
2: The tubing where the motor is mounted will need some support tubes added through the bolt holes, to prevent crushing. The motor has already rotated, and the chain no longer runs straight over the motor cogs.
3: The rear dropouts are 170mm wide. I found a Sturmey Archer 3 speed hub specially designed for this frame, and am awaiting delivery.
http://www.choppersus.com/store/product ... Disc-SLVR/
Original weight 21Kg. Weight now 29Kg.
The intended use is the 6Km trip to work, which is a little bit hilly.
Amanda
EVT-4000e. 16x TS-LFP40 and custom BMS = massive EV Grin
Chopper with 180 Watt Cyclone kit & 8x 20AHr Foxx LiFePO4 and custom BMS
knoxie   10 MW
Re: Chopper with Cyclone kit
Post by knoxie » Jul 05 2008 4:08am
Hi
Thats a nice looking little bike! well done, like the battery box as well will look nice painted up and plenty of room for more batteries as well, in fact if you are using lead you can stack a lot more lead inside that frame.
The cyclone is a good little kit for bike like this, the sturmey archer will make things better as the chain wont skip about as much.
Knoxie
Electric KMX 72V Lipo, USPD drive unit. BMX 72V, Puma BMC,
Raleigh 26 inch MTB Puma 50V Turnigy 25C Lipo 10AH, Trek MTB, X5 48V NIMH. Electric BMX
http://tinyurl.com/4vrmc8 http://tinyurl.com/3umm4n
AussieJester   100 GW
Post by AussieJester » Jul 05 2008 5:29am
Nice to see a member of the 'fairer' sex into the e-biking gig AND an Aussie too boot :-) Neat lil setup to Amanda, Alan from ChoppersRus is excellent to FYI very quick response to emails and gets the product away promptly with very reasonable freight charges compared to some of the suppliers i have had quotes from in the USA... 107 dollars US delivery for a scooter shockie that cost 17 bucks for example :-| I would look at slipping in a couple more batteries if you have the room there Amanda just to be sure you make the return trip from work without having to pedal... Will you be painting the battery 'box' up when your finished with the design etc? or keeping with the 'ghetto' look?
Top job anywayz well done :-)
EDIT: The shim material (extremely thin brass sheet) your after can be picked up from Model shops (as in the planes/helicopters/cars/boat models) to FYI in case your not sure where you can pick it up...
TylerDurden   100 GW
Post by TylerDurden » Jul 05 2008 9:01am
Looking good. :mrgreen:
(kinda like mine, before it was stolen by a gang) :(
re the motor mount: perhaps a metal plate (or two) that reaches as far back as the the chainstays.
Cheers...
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
AussieJester   100 GW
Post by AussieJester » Jul 05 2008 9:20am
Ah bugger TD what a pissa i gather you never saw it again? Curious how one of them 'gang members' you Americans have over there would actually get onto a bike in the first place what with the crotch of their pants hanging around their ankles with 27 inches of underwearz showing be a bit of a struggle to swing the leg over wouldnt it hehe ;-S
TylerDurden   100 GW
Post by TylerDurden » Jul 05 2008 9:53am
FWIW Commanda,
You could perhaps mount the motor above the pipe and keep your orig ground-clearance.
@ Jester.. it's usually kids <18yrs. Part of our goals with the inner-city bike co-op is to teach kids how bikes can be a part of good citizenship.
Have a Nice Day,
TD
docnjoj   100 GW
Post by docnjoj » Jul 05 2008 11:01am
Maybe give those "gang" members (not the real ones) summer jobs like they used to! Then they'll buy the bikes!! Nice job Amanda! Start saving for Ping,cause he's baaaaack!
otherdoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
commanda   100 W
Post by commanda » Apr 09 2011 9:11pm
Time for an update & some fresh piccies.
The batteries are now 8s * 20AHr Foxx prismatics which cost me $300.00.
And you can't put the motor on top, because the idler will be under tension, and it will bend the shaft.
Peak current to the Cyclone 180 watt motor is 30 amps.
The Sturmey-Archer 3 speed hub works a treat, and is a great combination with the Cyclone in our power restricted Aussie nanny state.
The little rack at the back is used to support my back-pack, which is held on with bungee cord.
The handle bar supports 2 mirrors, a bell, a horn, a Watts-up meter, and a gps.
Gearing is now 52 tooth front, 16 tooth rear. Top speed is about 30Km/Hr on the flat with a little pedalling.
BMS is custom, same as in my EVT scooter. Charger is currently a 30volt 3 amp benchtop power supply, but I do have a 27 volt Meanwell which I haven't implemented yet.
Power is enabled with a keyswitch driving a 24 volt automotive relay.
Last 2 weekends I've taken it out, done about 20Kms and used 9AHrs.
I've also ridden it to work a few times over the last few months. Only 5Km each way, but still a pleasure to arrive at work not sweaty.
Still to-do is find some decent material for the battery box, and put a lid on it so it is more weather-proof.
And find a cure for the rust.
It does get a lot of looks when out riding.
Amanda
Rassy   10 MW
Post by Rassy » Apr 09 2011 9:36pm
Bike looks nice. I had the same problem when I put a freewheel crank on my trike. My quick solution was to grind the "removal" tabs off the freewheel. Of course now I can probably never get the freewheel off again. :D
If (when) I have to redo it, I plan to just get a bottom brackett cartridge with a slightly longer axle.
-Rassy-
Two Delta Trikes equipped with a Bafang BBS02
viewtopic.php?f=28&t=88536&p=1291260#p1291260
amberwolf   100 GW
Post by amberwolf » Apr 10 2011 1:51am
If you're removing a freewheel like that because it's broken, you can just tackweld across the core to sprocket line, and then use a chainwhip to take it off. ;)
