KMX tornado
I built up a old KMX f8 Tornado it is a blast
Bought it used it was a Amazon return $500.00
they don't even make them any more
Modified seat Green Werks
20 inch rear wheel ERT
16 inch front wheels Toms ebike Barn
205 V2 35mm DD hub motor ERT
18 fet 100 amp 100 volt controller ERT
2 luna 52v 24 ah batteries in parallel set up for 80 amps
all wheel brakes
It is a blast00u0u_1uavESHhA7L_1200x900.jpgView attachment 1toms wheels 2.jpg
I am upping the bar on the kmx this winter
I am going to swap out the edge for a QS 50mm motor but
still run the 72v 30q battery from WCEC and the 18 fet controller from ERT
will be adding rear suspenshion
Along with the awesome Addam 333 front suspenshion
It should be a awesome bike path curser View attachment 1
Adam excellent work
That is a nice part you have made
mine set up is quite different in the aspect that a lot of the frame and swing arm is going to be modified
but I really like what you have done
Been a while since I put any thing up but trike is doing great
I really like running the two 52v batteries hooked together in parallel it makes it 48 ah
and 100 amps continuous and 140 amps burst I set the controller at
98 amps 94.39 amps.jpg with the 20 inch rear wheel it makes it a rocket from 0 to 30 mph then I shut down
Latest upgrade
Extended the front of the seat frame
Added 2 inch automotive seat foam
Very comfortable and the new deep bucket holds you in place
