I'm in the process of converting a Rover Mini to an EV using a Nissan Leaf. I'm at the point where I'll need to start doing some high voltage re-wiring to relocate the batteries and power module. I'm handy with crimpers and soldering irons, and I've worked with thick wiring for high-power 12V audio, but these orange high-voltage wires are new to me...I'm trying to figure out what the differences are between 12V wiring and 400+V wiring.
It's hard to find information, as "high voltage" usually means 1kW and above, whereas I'm working with a maximum of 400V in a Nissan Leaf pack. I either find household wiring info or 12V wiring info. I know P = A * V, but are there any other considerations? Are gauge calculations the same from DC to AC? How do I know how much insulation is safe at a particular voltage? I'd like to err on the side of too large a gauge for the power needs, just to eliminate it as a potential source for reduced performance (and future proofing).
- Can I use standard marine/auto/audio wiring for 400V without degrading performance or increasing danger?
- Is there anything special about crimping or soldering HV wire I should know about (vs 12V wire)?
- If I do need to buy wire and tools for this purpose, what's the good stuff? I usually buy marine-grade wire from Waytek for my stereos and what not. I found some stuff at EV West, but I can't say I understand the difference between the EV West cable, the Hew-Kabel cable, and Champlain EXRAD XLE cable...I have a bolt-cutter-style crimper that goes up to 1/0.
- When is it okay not to wear my 1000V rubber gloves when working with these batteries? Like, what can I touch when? Though I've melted a wrench across a 12V battery, most issues there are avoided by disconnecting the ground and not touching any power terminals.
