hi guys, first of all, let me introduce myself.
My name is Rick, 34 from the Netherlands.
I have build myself a 3 wheeled "transport bike"
And sadly, that's where the question is about :
Some specs :
Battery's 4x 70ah lead/acid semi traction battery's
Controller : brand new Kelly kbs48121
Hub motor : unknown 1500watt bldc motor
The problem :
As soon as I twist the throttle the wheel starts moving, but not fast and with a lot of noise/shaking. The controller trows a cell code : hall sensor fail..
OK clearly that's where I went checking..
Multimeter : black probe @black hall wire
Red probe @ yellow... Spinning the wheel.. On-off-on-off. Shows between 10/12 volt, switching to 0
Now I did the same for green... Same result..
Blue : strange: Shows around 5 volts and not going 0.
OK, bad hall sensor right?
But now I replaced ALL hall sensors 3 times, and checked the wires 4x but still the same error...
Am I doing something wrong or is it the controlller.
Any idea?
Some specs :
The problem :
Any idea?
