building a "T bucket of bolts"
DougEB
10 µW
re-erecting a "hot rod" I constructed several years ago and upgrading the motor and battery.
HAD a cyclone 24v 500 watt electric motor with a home build freewheel differential.
Purchased a 1800w 4500 rpm motor and a differential off of an MTD lawn mower.
The differential has 13.5 to 1 ratio and driving it from the motor 13 to 1 ratio (ending ratio around 26 to 1 ratio). I need to recount drive sprockets but 26 to 1 is close.
The drive wheels are 26" fat tires (29" diameter)
Hopefully this will work.
The 500 w motor would drain the battery too fast(not enough POWER)
desired max speed is 15mph and hopefully the motor won't get overworked.
using same motor as Edstreetrunner is using.
[/url]/img]
this pic is several years old showing peddles etc. which are being removed
any suggestions?
this is same motor I am using
https://endless-sphere.com/forums/viewtopic.php?f=7&t=104270#p1522501
[/url][/img]
will get this pic sooner or later
https://i.postimg.cc/2SzKstTL/parade-1.jpg
