calab said:
Mosfets are like $4-5 each, an ebike controller can have 18 mosfets, that $90 just in mosfets, unless you go with something cheaper, then there is the micro-controler, maybe $30???? who knows.Check it out for yourself at mouser.com.
Thats my effort.
A controller can have any multiple of six for a three phase. So that means 6, 12, 18, 24, ect. A pair is minimum for every phase. Paralleled for more current handling. You need at least two for each bridge, minimum. For the switching.
I need two more of these. For a custom controller I want to build. 300A/1200v. They are 194$ each. ( 1200$ total)... If I want to meet 480A @ 1200v, that increased to 370$ ea.. now.. and I pay.....2,200$ for those 6. Controller will need need $ worth of IGB Transistor. Fast acting freewheeling diode with a 1.5kW dissipate rating each. Hellyeah. 1.5kW per, x6, so 9kw, just to get the heat out of the controller under this theoretical Ifull load I have to dissipate 9 kW of bTu energy.
So yea they cut corners on this part, for it is expensive. Even at 5$ ea you are paying 90$ for 18 of them yeah. So cheap controller builders really skimp on the transistors usually.
https://www.radwell.com/Shop?source=GoogleShopping&IgnoreRedirect=true&ItemSingleId=99689069&utm_source=google&utm_medium=cpc&adpos=&scid=scplp99689069&sc_intid=99689069&gclid=Cj0KCQjwma6TBhDIARIsAOKuANyLQqAhM92qQU6m1W0X4rBY0QdusZYQWzklI5GrjfYmfSHtzBzDNhEaArhjEALw_wcB
https://www.mouser.com/ProductDetail/Infineon-Technologies/BSM150GB120DN2?qs=MiMjeza5s%252BStCNCaULatRw%3D%3D
I have here: Ebike controllers.
A very cheap 55A 120v ZLmotor Sine controller.
75$.
A med. priced Kelly,
250$, 3.3kW, and a higher priced Kelly.
350$. 4.5kW.
A Lyen 4115 134v 70A that some people have peaked past 400 phase amps with. Cost
449$ like seven, eight years ago.
A junkyard Curtis. cannot use it. Need an expensive programming dongle. it was
2$.
I am ( trying to) buying another soon. A 14kW. Gonna be
expensive. You see the spread of quality component.
You see the Sevcons. ...you see the controllers that use the IGBT for the bridges.... Car movers... MC controllers... Real controllers. Not the bank of MOS field effect transistor thingys.
They get expensive. Under 100$ is bottom line, bargain bin electronics.
