Master a perfect inline wire splice
LockH   100 GW
Post by LockH » Jul 31 2016 12:45pm
... everytime
Seen on site "Instructables":
http://www.instructables.com/id/Master- ... everytime/
(Currently "618,231 views, 441 favorites")
viewtopic.php?f=3&t=57408
viewtopic.php?f=15&t=60564
dogman dan   100 GW
Re: Master a perfect inline wire splice
Post by dogman dan » Aug 05 2016 6:48am
Well sure, way easy with wire that small. Not so easy with 10g wire on a hobby king pack. That's why I went to those crimp sleeves. Not automotive butt connectors, the crimp sleeves for house wiring.
LockH   100 GW
Post by LockH » Aug 05 2016 7:14am
Hehe... Wasn't thinking main power cables, but at least for those "house" wiring thingees. Those electric bits running off a DC-DC converters etc. using lower power (and smaller wires). :)
Punx0r   100 GW
Post by Punx0r » Aug 05 2016 8:09am
Not the quickest way, but for large wires you can mesh the two ends together then bind it with a single strand of thin wire before soldering.
Bicycle365   1 mW
Post by Bicycle365 » Aug 11 2016 4:20pm
@PunxOr +1 that method
10 AWG High Strand Silicone Butt Splice.
This is my method for multistrand.
For solid core the good ole' Western Union splice, hundred years old and adopted into the NASA builders book as the preferred method !
Look at your join date and your # of posts. If >1 per day, please read more and type less. We will both be smarter for it.
Ypedal   100 GW
Post by Ypedal » Aug 11 2016 4:43pm
for most 12g or smaller things i just pre-solder 1/4" worth of wire end, line them up side by side and re-melt the solder for a second.. you end up with a much tidier splice and less of a stiff section. has never let me down. ( specially when soldering up hub motor cable with 3 thick and 5 thin wires into a small heat shrink length )
ES site status page:
amberwolf   100 GW
Post by amberwolf » Aug 11 2016 5:10pm
However you splice it, I would definitely recommend offsettingg every splice point from every other so that when all the wires overlap, noen of h te splice points are next to each other. This prevents shorts if you mess up insulating them, and makes the bundle not a giante lump in one place. :)
spinningmagnets   100 GW
Post by spinningmagnets » Jan 26 2020 8:24am
The Amberwolf method, my favorite.
Hillhater   100 GW
Post by Hillhater » Jan 26 2020 5:58pm
And the professional method..
Self soldering
Self Insulating
Waterproof self sealing
https://youtu.be/7Wh5gM8GM70
Toorbough ULL-Zeveigh   100 MW
Post by Toorbough ULL-Zeveigh » Jan 28 2020 5:48pm
spinningmagnets wrote:
Jan 26 2020 8:24am
in that case yoos gotz sum royalties coming your way. :roll:
for those rare instances when improved flexibility is demanded.
solder tack a copper chinese finger trap over the ends instead of wire wrap.
markz   100 GW
Post by markz » Mar 07 2020 5:18pm
markz   100 GW
Post by markz » Mar 07 2020 5:19pm
dogman dan wrote:
Aug 05 2016 6:48am
Like this?
https://www.electriciantalk.com/f29/cri ... es-195537/
Post by Toorbough ULL-Zeveigh » Mar 11 2020 2:15pm
like this minus the hammering is E*S tight-bastard preferred method
