Could someone help me figure out this HONDA BMS?
Offroader   100 MW
Post by Offroader » Sep 19 2017 12:37am
This is from a Lithium titanate Honda FIT EV car. I have the 30 volt pack with attached BMS.
The BMS doesn't seem to be doing anything, I charged and discharged cells by 1 amp hour and they just stay unbalanced. All cells were balanced by .002 when I opened the pack up.
Some ideas:
Does the BMS need to be powered through the 6 pin connector or connected to the car to work? Does the BMS need to be charged or discharged at the pack level for it to work?
If anyone has any idea on what I could do to get this to balance, thanks.
Pictures below will be cut off, so you will have to right click over picture and use "open image in new tab" and then scroll left and right. Or save image to hard drive and view it.
Or click on the links below.
https://imgur.com/bf0OL3r
https://imgur.com/3Yjq94H
https://imgur.com/t1wfS9O
https://imgur.com/E35l6V7
https://imgur.com/OeCP9Ou
https://imgur.com/8CbmTXH
https://imgur.com/OjpKs9z
https://imgur.com/E4vvjDt
https://imgur.com/LVDYBLz
https://imgur.com/RA6d4ah
Thank you
okashira   10 kW
Re: Could someone help me figure out this HONDA BMS?
Post by okashira » Nov 19 2017 3:12am
How did you get this car. They were supposed to be destroyed./ Recycled.
I want that pack. :D
"Peace out - I'm done."
-- Bernhard Riemann, 1859
edisonmotors.net
Tesla Model S 18650 cells - like new - and custom packs from Tesla cells for sale. Any shape Any power Any capacity.
PM me or search my threads.
Fishybob   1 µW
Post by Fishybob » Jan 30 2019 10:10pm
The BMS requires a seperate dc supply (I think the main micro-controller came to life when the supply hit 6 or 7 vdc but have used 12v.)
The board spits out CAN bus messages with encoded cell voltage (3 messages with binary codes for 4 cell voltages each) shortly after power-up.
I have one board with microcontroller debug connectors soldered on for both the low voltage (isolated) and high voltage sides and have identified the non-standard baud rates used on the debug serial ports.
I Have not tried taking the cells out of balance to see if balancing is enable at "power up".
I have not been able to decode much more than the cell voltage.
I have not been able to identify the main AFE/BMS chip and have set the project aside for now.
I can dig up my notes if you are still interested.
Scott.
dapsyra66   1 µW
Post by dapsyra66 » Feb 16 2019 2:06pm
I have some of the Honda FIT LTO batteries which have been deployed in solar storage.
Can I have your notes on the BMS so that I can try my hands on making the inbuilt BMS functional.
Thank you.
max22   1 µW
Post by max22 » Jun 10 2019 5:03pm
I'm also interested in any notes on the BMS if anyone is looking at the pack. Or just to know if anyone has been using this pack as-is, and if the cells stay balanced passively with moderate charging/discharging?
Fishybob   1 µW
Post by Fishybob » Jun 13 2019 12:29pm
Hi Max22
If you have the 8 pin connector with 6 wires that was plugged into the balance board the wires are:
Red (V+) DC Supply (I have used 7-12vdc)
Black (V-)
White (CANH) CAN Bus
Yellow(CANL)
Brown(CANH) CAN Bus (same as above.)
Blue(CANL)
Using a raspberry pi with a CAN transceiver board and "can-tools" I can read repeating 8 byte messages from each board all of which contain four 12-bit cell voltages (in the first 6 bytes) and a "group" number (2 MSB of the 8th data byte.) Group b00 indicates voltages for cells 1-4, b01 indicates voltages for cells 5-8, and b10 indicates voltages for cells 9-12.
rpi> sudo ip link set can0 up type can bitrate 500000
pi@RPI0W:~/my $ candump can0 -n3
can0 20A [8] 00 00 00 00 00 00 24 06
can0 20A [8] 00 00 00 00 00 00 21 54
can0 20A [8] 53 AC FE CF EC FE 02 A3
pi@RPI0W:~/my $ candump can0 -i -n3
can0 20A [8] 00000000 00000000 00000000 00000000 00000000 00000000 00100100 00000110
can0 20A [8] 00000000 00000000 00000000 00000000 00000000 00000000 00100001 01010100
can0 20A [8] 01010101 01101100 11111110 11001111 11101100 11111110 00000010 10100101
cell 1 = b000000000000 * 1.5 mV = 0.000v
cell 12 = b110011111110 * 1.5 mV = 4.989v
(dump above is from board not attached to cells.)
I have some balance boards with duplicate "addresses" (the 0x20A above) and would trade them for addresses I don't have so that I can easily read all cell voltages from a string of battery modules on a single can bus.
If you (or anyone else) get this far (or further) let me know and I can dig up more details.
Scott.
Offroader   100 MW
Post by Offroader » Jun 14 2019 8:25pm
max22 wrote:
Jun 10 2019 5:03pm
I have been using 3 and half a pack of these, or 84 cells in my hybrid car with no BMS. The cells have stayed perfectly balanced for over a year already.
You just need to check them for bad cells as some of these can have bad cells. They will go out of balance if the cell is bad.
IamIan   100 mW
Post by IamIan » May 07 2020 3:29pm
Fishybob wrote:
Jun 13 2019 12:29pm
FYI
A little bit of progress with
1st gen Honda Insighter's using them for PHEV conversions.
https://www.insightcentral.net/threads/ ... on.125085/
Some BMS board swapping is available if you still want / need non-duplicates.
  • Life Long Energy Efficiency Enthusiast
  • Folding , sealed chainless 8spd shaft drive, SmartPie4 front hub, 350 Calorie LiFePO4 , Cycle-analyst meter
  • oo-MT-Insight +MIMA+FAS+GridCharger+OBDIIC&C ~LiFePO4 in progress
Offroader   100 MW
Post by Offroader » May 07 2020 9:44pm
Thanks, yeah they finally got that BMS working.
I'm kind of too lazy to do anything about this now because after using these cells in my hybrid car for 2 years now, I have yet have one single cell go out of balance. Still within .003 volts of each other.
IamIan   100 mW
Post by IamIan » May 09 2020 2:56pm
Offroader wrote:
May 07 2020 9:44pm
not yet 100% .. but ..
For anyone who has one of those OEM BMS 12s boards , and wants to put it to some use.
Sense they come 'included' with the $265 for 1.1kwh LTO module .. it's not a bad deal .. battery cells and cell level voltage monitoring.
https://greentecauto.com/hybrid-battery ... i-ion-scib
For the moment .. cell level battery voltage monitoring is unlocked via isolated CAN communication .. be it for 12s , 24s , 36s, 48s, 60s , 72s , etc .. one just needs each BMS to use a different ID # .. but on the above InsightCentral forum link members have extra boards they will swap with people to achieve that.
The cell to cell balancing function is not 'on' by default .. it has to be commanded to turn on for specific cell .. have not yet figured out what that specific CAN command is.
Offroader wrote:
May 07 2020 9:44pm
Understandable.
I got some to put to use in a ~12kwh home solar battery .. that will (with ~20,000 cycle life) hopefully last for several decades.
Fishybob   1 µW
Post by Fishybob » May 16 2020 10:35am
IamIan wrote:
May 07 2020 3:29pm
Fishybob wrote:
Jun 13 2019 12:29pm
FYI
Thanks for the heads up Ian. (I am going to spend a little more time with this BMS board and will post progress on insightcentral.net as that discussion looks more lively.)
