Mini-El City-El cityel Curtis, motor
pavlik1
Switzerland
Hello
I got old City-El, in good condition, still need some improvements.
The car is with compound motor Thrige TTL140 and 1204 Curtis controller. There are 4 contactors and additional board for regenerative breake.
I am looking for other controller which has the in-build regenerative function, programming interface and may eliminate the need of the contactors.
I come across some Curtis controllers which may fit like SepEx type 1266 for example. So far I am not sure if it can work with compound motor. Any help or experiance here is strongly appreciated
The original motor connection is:
The 1266 connection is:
The battery will be made of 16S LiFePo Winston 100Ah yellow cells
The battery are installed and balancing very good.
https://youtu.be/_kLciG6Ryng
So far it consumes app 1ah per km at speed over 50km/h
Top on flat is 65, downhill 80...
Sent from my SM-G950F using Tapatalk
hi, still working on the city el?
I just found one and its working.. pfiew.. :)
but.. the motor is getting very hot, as is the controller.
before I put in a brushless motor and controller, I would like to hear if it is worth the money and the hassle..
what would you guys do?
thanks
