LG MH1 Cell which have very few cycles $2.
These cells are capacity testing at and above the original manufacturers spec.
Professionally recovered, inspected and tested. All nickel material has been removed and are ready to go right into your next project.
All cells are guaranteed to exceed 90% original capacity specification of 3200mhA I will replace for free and pay shipping.
Orders shipped from Seattle Washington, USA
Minimum order is 20 cells, you can order more. If you need substantial more contact me about pricing and availability. I ship the following day and provide tracking immediately after.
PM me to place an order. I ask for 25% down and the balance paid when you receive your tracking number.
SPECIFICATIONS:
LG INR18650MH1
Brand LG
Model INR18650MH1
Manufacturer LG Chemical
Country. South Korea
Weight. 49.00 g
Diameter 18.40 mm
Height. . 65.10 mm
Voltage max. . 4.20 V
Voltage nominal. 3.63 V
Voltage end 2.50 V
Capacity max. 3200.00 mAh
Constant charge max. 3.10 A
Charge constant 1.55 A
Discharge standard 620 mA
Max. cont. discharge 10.00 A
Peak discharge 17.5 A
C-rate charge, max. 0.97 C
C-rate discharge max 3.13 C
Watts charging 11.253 W
Watts discharging 36.3 W
Energy, max. 11.62 Wh
E-rate (charge, max.) 0.97 E
E-rate (discharge, max.) 3.12 E
Standard charge 2.5 hours
Rapid charge 2 hours
Internal impedance 7 mΩ
SPECIFICATIONS:
LG INR18650MH1
Brand LG
Model INR18650MH1
Weight. 49.00 g
Diameter 18.40 mm
Height. . 65.10 mm
Voltage end 2.50 V
