[$1.25 per cell] lg 18650 mh1 3200 mAh REFURBISHED
Los Angeles
Hello everyone. My name is Aleksei, we are a new startup company called American Electric Solutions LLC, we specialize in refurbishing and destribution of unused Li-Ion battery packs and cells from various suppliers.
This listing is for refurbished and unused LG MH1 18650 cell. We extract them from unused battery packs that were in storage since 2021, so some capacity degradation is expected.
All spot weld marks have been removed, the cells are ready to be assembled in new battery packs.
All cells are tested for performance and capacity and we guarantee 95% capacity on all of them, otherwise you get either a replacement or a refund.
You are getting brand new quality & capacity, for the price of "used" cells which would normally have noticeably decreased capacity.
All orders of 40 cells and over will arrive in free hardened plastic honeycomb style cell holders for 40 cells, with threaded mounting holes and room for bms (see attached photo). These cell holders are free of charge to you, they are worth about $15 each.
Here are the specs:
Brand: LG
Model name(s): LG18650MH1,INR18650MH1,INR18650-MH1,ICR18650MH1
Origin: South Korea
Weight: 49.00 g
Typical Capacity: 3200mAh (at least 95% capacity guaranteed)
Nominal Capcity: 3100mAh
Diameter: 18mm
Length: 65mm
Voltage nominal: 3.6V
Charge voltage cut-off: 4.2V
Discharging cut-off: 2.5V
Standard charge: 2.5 hours
Rapid charge: 2 hours
Watts (charge, max.): 11.253 W
Watts (discharge, max.): 36.3 W
Energy, max.: 11.62 Wh
Maximum charge rate: 3.10 A
Standard charge rate: 1.55 A
Minimum charging temperature: 0.00 °C
Maximum charging temperature: 45.00 °C
Minimum discharge temperature: -20.00 °C
Maximum discharge temperature: 60.00 °C
Storage (less than 1 month): -20 – 60 °C
Storage (less than 3 month): -20 – 45 °C
Storage (less than 1 year): -20 – 20 °C
Max. continuous discharge current: 10.00 A
Peak discharge theoretic, 4 sec: 17.5 A
E-rate (charge, max.): 0.97 E
E-rate (discharge, max.):3.12 E
C-rate (charge, max.): 0.97 C
C-rate (discharge, max.): 3.13 C
Internal impedance: 7 mΩ
Chemical abbreviation: NMC
Cathode: LiNiMnCoO2
Anode: carbon
Remark: Ni-Rich
SHIPPED PRIORITY MAIL FROM USA,SAME BUSINESS DAY
PACKED BY A CERTIFIED PACKAGING EXPERT, COMES IN DENSE INDUSTRIAL GRADE CELL HOLDERS (free)
Ask for a shipping quote. A standard $16 USPS Medium Flat Rate Box can fit up to 200 cells.
All transactions are made through paypal with tracking, so you either get your package or a refund.
Here is an in-depth data sheet about the cell, it's testing and origin
Be advised, this testing data is from 2015. LG Chemical improved the chemistry of this cell in the last 7 years.
The number of full charge-discharge cycles has increased and cell degradation has decreased.
The link to the review from 2015:
https://voltaplex.com/media/whitepapers/specification-sheet/LG_MH1_Specification_Sheet.pdf
1 Positive.png2 Negative.png3 positive.png4 negative.png5 cell holder.png6 cell holder.png7 cell holder.png
Im interested in purchasing some of the cells to make a battery pack for my bike build. Are they still available and how do I go about purchasing them if so. I'm new to this forum so not sure how things are done exactly but heres my email vincent.brian.2536@gmail.com and I'm Brian Vincent thank you for your time.
ISNT this illegal? USPS will NOT allow that, nope, no way no how. Hell no you cannot ship lithium through Priority mail.
Not the best way to start a business, shipping illegally and putting people art risk for your profits.
349 Miscellaneous Hazardous Materials
(Hazard Class 9)
349.1 Definition
A miscellaneous hazardous material is a substance or article that presents a hazard during transportation, but does not meet the definition of any other hazard class. Examples of miscellaneous hazardous materials (not all of which are mailable) include solid dry ice, lithium batteries, magnetized materials, elevated temperature substances, environmentally hazardous substances, life-saving appliances (i.e., automobile air–bags, self-inflating life vests), and asbestos. Miscellaneous hazardous materials include:
Any material that has an anesthetic, noxious, or other similar property that could cause extreme annoyance or discomfort to a flight crew member.
Any elevated temperature material, hazardous substance, hazardous waste (other than Division 6.2 medical waste), or marine pollutant.
349.11 Lithium Battery — Classifications:
Lithium-ion cell or battery means a rechargeable electrochemical cell or battery in which the positive and negative electrodes are both lithium compounds constructed with no metallic lithium in either electrode. These batteries are also referred to as secondary or rechargeable lithium cells or batteries, and are typically used in cell phones and laptop computers.
Lithium-ion polymer cell or battery means a rechargeable cell or battery that uses lithium-ion chemistries and is regulated as a lithium-ion cell or battery.
Lithium metal cell or battery means an electrochemical cell or battery utilizing lithium metal or lithium alloys as the anode. The lithium content of a lithium metal or lithium alloy cell or battery is measured when the cell or battery is in an undischarged state. The lithium content of a lithium metal or lithium alloy battery is the sum of the grams of lithium content contained in the component cells of the battery. These batteries are also referred to as primary or nonrechargeable lithium cells or batteries, and are often used in consumer products such as cameras and flashlights.
Button cell battery means a small single cell round battery with the overall height less than the diameter. Button cells are used to power small portable electronic devices such as wrist watches, pocket calculators, and hearing aids, and are often installed in electronic devices as auxiliary power sources. For the purposes of mailability as button cell batteries, lithium metal batteries must contain no more than 0.3 gram of lithium content and lithium-ion batteries must be 2.7 watt-hours or less.
Lithium cell means a single encased electrochemical unit with a single positive electrode (anode) and single negative electrode (cathode), which exhibits a voltage differential across its terminals. For the purpose of mailability, marking, and documentation requirements, a single cell lithium battery is classified as a lithium cell.
Lithium battery means one or more lithium cells which are electrically connected together by a permanent means, including case, terminals, and markings.
349.12 Lithium Battery — Definitions
Equipment means the device or apparatus for which the lithium cells or batteries will provide electrical power for its operation.
Lithium battery consignment means one or more mailpieces containing lithium batteries, entered into USPS networks by one mailer or mail service provider within a single mailing or retail transaction, or included in the same manifest or shipping services file, and intended for delivery to a single consignee at a single destination address.
Short circuit means a direct connection between positive and negative terminals of a cell or battery that provides an abnormally low resistance path for current flow.
Watt-hour (Wh) means a unit of energy equivalent to one watt (1 W) of work acting for one hour (1 h) of time. The watt-hour rating of a lithium-ion cell or battery is determined by multiplying the rated capacity of a cell or battery in ampere-hours, by its nominal voltage. Therefore, watt-hour (Wh) = ampere-hour (Ah) x volts (V).
349.2 Mailability
International Mail. All miscellaneous hazardous materials are prohibited, except for certain magnetized materials as permitted in 349.242a and IMM 136.1g, and small consumer-type lithium batteries (installed in the equipment they operate) as permitted in 622.5 and IMM 135.6.
Domestic Mail. A miscellaneous hazardous material that can qualify as a mailable air-eligible consumer commodity material (ID8000) when intended for air transportation, or limited quantity surface material when intended for surface transportation, is permitted in domestic mail, subject to the applicable 49 CFR requirements. Only certain materials within Classes 2, 3, 6.1, and 9 are mailable by air transportation; mailpieces including eligible quantities of these materials must be marked with the proper shipping name “Consumer Commodity.” Additionally, lithium batteries, dry ice, and magnetized materials are permitted within the specified limits provided in 349.221, 349.222, 349.23, and 349.24.
349.21 Nonmailable Class 9 Materials
The following materials are prohibited:
All Class 9 materials that cannot qualify as a Limited Quantity air or Limited Quantity ground material, except for lithium batteries, dry ice, and magnetized materials.
All magnetized materials that have a measurable magnetic field strength greater than 0.00525 gauss at 15 feet.
For air transportation, all magnetized materials that can cause a compass deviation at a distance of 7 feet or more.
In domestic mail via air transportation, dry ice in quantities exceeding 5 pounds per mailpiece.
All lithium batteries in international mail, unless they are within the specified limits and only when properly installed in the equipment they operate.
All lithium batteries in domestic air transportation, unless they are within the specified limits and only when properly installed in, or packed with, the equipment they are intended to operate.
349.22 Mailable Class 9 Materials
349.221 Lithium Metal (Nonrechargeable) Cells and Batteries — Domestic
For domestic mailings only, small consumer-type lithium metal cells or batteries (also called primary lithium cells or batteries) like those used to power cameras and flashlights are mailable domestically under the following conditions. See 622 or IMM 136 when mailing batteries internationally or to APO/FPO/DPO destinations.
General. The following restrictions apply to the mailability of all lithium metal (or lithium alloy) cells and batteries:
Each cell must contain no more than 1.0 gram (g) of lithium content per cell.
Each battery must contain no more than 2.0 g aggregate lithium content per battery.
Each cell or battery must meet the requirements of each test in the UN Manual of Tests and Criteria, part III, and subsection 38.3 as referenced in DOT’s hazardous materials regulation at 49 CFR 171.7.
All outer packages must have a complete delivery and return address.
All packaging must meet applicable requirements specified in 49 CFR 173.185. Except for mailpieces containing button cell batteries properly installed in the equipment they are intended to operate, mailpieces containing lithium metal batteries must be rigid, sealed, and of adequate size, so the mark can be affixed to the address side without the mark being folded. The use of padded and poly bags as outer packaging is permitted only when the mailpieces contain button cell batteries meeting the classification criteria in 349.11d, the batteries are properly installed in the equipment they are intended to operate, and the batteries are afforded adequate protection by that equipment.
Except for mailpieces containing button cell batteries installed in equipment (including circuit boards), or no more than 4 lithium metal cells or 2 lithium metal batteries installed in the equipment they operate, mailpieces containing lithium metal batteries must bear a DOT-approved lithium battery mark, as specified in 49 CFR 173.185(c)(3)(i) and Exhibit 325.2a, applied to the address side of the mailpiece. Marks must not be applied in such a manner that parts of the mark appear on different sides of the mailpiece.
The mark must indicate UN3090 for lithium metal cells or batteries. UN3091 must be indicated where the lithium cells or batteries are contained in or packed with the equipment they are intended to operate. The mark must also include a telephone number for those who need to obtain additional information.
Installed in Equipment. The following additional restrictions apply to the mailing of lithium metal cells or batteries properly installed in the equipment they operate:
The batteries installed in the equipment must be protected from damage and short circuit.
The equipment must be equipped with an effective means of preventing it from being inadvertently turned on or activated.
The equipment must be cushioned to prevent movement or damage and, unless excepted under 349.221a(5), must be contained in rigid outer packaging, sealed and strong enough to prevent crushing of the package or exposure of the contents during normal handling in the mail.
For lithium metal cells and batteries containing no more than 0.3 gram of lithium content, no mailpiece may exceed 2.5 kilograms (5.5 pounds). There is no maximum number of cells or batteries per mailpiece.
For lithium metal cells containing more than 0.3 gram but no more than 1.0 gram of lithium content, and batteries containing more than 0.3 gram but no more than 2.0 grams of lithium content, no mailpiece may exceed 5 kilograms (11 pounds). Each mailpiece may contain a maximum of 8 cells or 2 batteries, with no more than 1.0 gram of lithium content per cell or 2.0 grams of lithium content per battery.
When required or optionally applied, mailpieces must display a DOT-approved lithium battery mark on the address side.
DOT-approved lithium battery markings must be applied to all mailpieces when there are more than two mailpieces in a single consignment as defined in 349.12b.
Mailed With Equipment. The following additional restrictions apply to the mailing of lithium metal cells or batteries shipped with (but not installed in) the device or equipment being mailed:
The shipment cannot contain more batteries than the number needed to operate the device.
The lithium metal cells and batteries must be packaged separately and cushioned to prevent movement or damage.
The shipment must be cushioned to prevent movement or damage, and must be contained in rigid outer packaging, sealed and strong enough to prevent crushing of the package or exposure of the contents during normal handling in the mail.
Mailpieces must display a DOT-approved lithium battery mark on the address side.
Mailed Without Equipment. The following additional restrictions apply to the mailing of lithium metal cells or batteries without equipment (individual batteries):
The lithium metal cells and batteries must be mailed in “the originally sealed packaging.”
The sealed packages of batteries must be separated and cushioned to prevent short circuit, movement, or damage.
Mailpieces must be sent by surface transportation only.
Mailpieces must display a DOT-approved lithium battery mark on the address side, in addition to the text “Surface Mail Only, Primary Lithium Batteries — Forbidden for Transportation Aboard Passenger Aircraft” or “Surface Mail Only, Lithium Metal Batteries — Forbidden for Transportation Aboard Passenger Aircraft.”
The mailpiece must not exceed 5 pounds.
349.222 Lithium-ion (Rechargeable) Cells and Batteries — Domestic
Small consumer-type lithium-ion cells and batteries (also called secondary lithium cells or batteries) like those used to power cell phones and laptop computers are only mailable domestically under the following conditions. See 622 or IMM 135.6 when mailing batteries internationally or to and from APO/FPO/DPO destinations.
General. The following additional restrictions apply to the mailability of all secondary lithium-ion or lithium polymer cells and batteries:
The watt-hour rating must not exceed 20 Wh per cell.
The watt-hour rating must not exceed 100 Wh per battery.
Each battery must bear the “Watt-hour” or “Wh” marking on the battery to determine if it is within the limits defined in items 1 and 2.
All packaging must meet applicable requirements specified in 49 CFR 173.185. Except for mailpieces containing button cell batteries properly installed in the equipment they are intended to operate, mailpieces containing lithium-ion batteries must be rigid, sealed, and of adequate size, so the mark can be affixed to the address side without the mark being folded. The use of padded and poly bags as outer packaging is permitted only when the mailpieces contain button cell batteries meeting the classification criteria in 349.11d, the batteries are properly installed in the equipment they are intended to operate, and the batteries are afforded adequate protection by that equipment.
Except for mailpieces containing button cell batteries installed in equipment (including circuit boards), or no more than 4 lithium-ion cells or 2 lithium-ion batteries installed in the equipment they operate, mailpieces containing lithium-ion batteries must bear a DOT-approved lithium battery mark, as specified in 49 CFR 173.185(c)(3)(i) and Exhibit 325.2a, applied to the address side of the mailpiece. Marks must not be applied in such a manner that parts of the mark appear on different sides of the mailpiece. Where the lithium cells or batteries are shipped separately from equipment, the mark must indicate UN3480. Where the lithium cells or batteries are contained in, or packed with, equipment, UN3481 must be indicated. The mark must also include a telephone number for those who need to obtain additional information.
Installed in Equipment. The following additional restrictions apply to the mailing of lithium-ion cells or batteries properly installed in equipment they operate:
The equipment must be cushioned to prevent movement or damage and, unless excepted under 349.222a(6), must be contained in rigid outer packaging, sealed and strong enough to prevent crushing of the package or exposure of the contents during normal handling in the mail.
For lithium-ion cells and batteries with a watt-hour rating of not more than 2.7 Wh, no mailpiece may exceed 2.5 kilograms (5.5 pounds). There is no maximum number of cells or batteries per mailpiece.
For lithium-ion cells with a watt-hour rating of not more than 20 Wh, and batteries with a watt-hour rating of not more than 100 Wh, each mailpiece must contain no more than 8 cells or 2 batteries. Each cell must have a watt-hour rating of no more than 20 Wh, and each battery must have a watt-hour of no more than 100 Wh.
Mailed With Equipment. The following additional restrictions apply to the mailing of lithium-ion cells or batteries shipped with (but not installed in) the device or equipment being mailed:
Mailed Without Equipment. The following additional restrictions apply to the mailing of lithium-ion cells or batteries without equipment (individual batteries):
The lithium-ion cells and batteries must be mailed in “the originally sealed packaging.”
Unless both mailed from, and intended for delivery to, the state of Alaska under 349.222d(7), mailpieces must be sent by surface transportation only.
Mailpieces must display a DOT-approved lithium battery mark on the address side, in addition to the text “Surface Mail Only, Secondary Lithium Batteries — Forbidden for Transportation Aboard Passenger Aircraft” or “Surface Mail Only, Lithium-ion Batteries — Forbidden for Transportation Aboard Passenger Aircraft.”
Cells having a watt-hour rating of not more than 20 Wh, and batteries having a watt-hour rating of not more than 100 Wh may be mailed via air transportation only when both mailed from, and intended for delivery within, the state of Alaska. Each mailpiece must contain no more than 8 cells or 2 batteries.
So which battery seller ships legally following all regulations!?
But I agree USPS is really the worst idea!
Me.
.. and anyoone else whom does not want to danger people or break laws. Most reputable sellers. Hey I tried, thought about shipping willy nilly... but since I saw what happened with Jehu Garcia ( shipping things that caught fire, in boxes with the ( real) shipping warnings spraypainted over) I decided it was a trash ideal... just break rules for money. . Dont lke it. Aint gonna do it. I now have hooked up with the owner or LIONWHOLESALE.COM and he ships anything for me if I package and label it right, on his account. He is a great guy. A real down to earth businessman.
https://liionwholesale.com/
:bigthumb:
DOT busted Luna.
Here are the specs:
Brand: LG
Origin: South Korea
Weight: 49.00 g
Diameter: 18mm
Length: 65mm
Cathode: LiNiMnCoO2
Anode: carbon
Remark: Ni-Rich
View attachment 324455View attachment 324456View attachment 324457View attachment 324458View attachment 324459View attachment 324460View attachment 324461
Hello. I was wondering if you refurbish batteries for Greenworks or Ego lawn equipment. My Greenworks are 60v 8ah and my Ego are 56v 2.5ah and 4ah batteries.
