MGM HBC 280120-3-EI 34KW ESC 120V 280A Controller - sold
Wiesbaden
Selling here a used MGM controller, which was only briefly in use.
The controller is fully functional.
As equipment it has some options.
Special feature is the possibility to connect motors with Hall sensors, an external MOSFET temperature sensor and extended inputs and outputs, CAN, etc.
The new price is currently 2500€.
The exact data of the controller can be found on the internet. Detailed order spec sheet can be sent.
Additionally I offer the following parts for an extra charge:
-Voltage indicator up to 150V: Practical to check the state (charged/uncharged) of the capacitors
-USBCOM 5i: Data communication PC to controller
-Capacitorbank: Highly recommended to reduce voltage spikes and thus the total failure of the controller
-ON/OFF switch
-Precharge cable: This is used to precharge the capacitors in a controlled manner without creating a spark when the battery is plugged in, which would destroy the contacts. The original "Precharge" option of the controller does not work when an additional capacitor bank is used.
-Y-cable for battery and phases
-Temperature sensor KTY/210
Paypal payment possible
Shipping from Germany
SOLD!
