High power Ebike for sale, UK only.
Richard F
Due to moving I'm unable to take it will me, a sad day as I've put 2 years of work into it :(
but I'm hoping it will find a good home . im looking for £1200
Kelly 120amp ESC with Bluetooth programming 80amp BMS 20ah 13s 22650 cells peak discharge rating 200amps
24inch 2000w hub, plenty of power and the motor stays cool at my config, but you can push it harder if you're that crazing
the acceleration is amazing , even up step hills , Regan braking
4 pot downhill hydraulic brakes 203mm ice-tec rotors
motorbike DMN rear shock rebound and hardness settings , std rock shock front fork
so many more things to add , but if you'd like to know more feel free to call me
on 07729869086
kind regards
Richard
from the Telford View attachment IMG_20221022_145404.jpgView attachment IMG_20221022_145404.jpgView attachment IMG_20221022_145344.jpgView attachment IMG_20221022_145551.jpgView attachment IMG_20221022_145457.jpgView attachment IMG_20221022_145334.jpgView attachment IMG_20221030_150836.jpgIMG_20221030_150709.jpg
