many Falco motors and parts for sale (also new)
Have extra parts that need a good home? Post it up here and see if anyone else is searching for what you are selling.
burner77   100 W
Post by burner77 » Apr 16 2015 4:59am
The motor is build to work also without ANT+ connector, display, +/- buttons
burner77   100 W
Post by burner77 » Jun 15 2015 11:10am
I have bougth tons of Falco motors stuff from Team Hybrid in the UK and I want to share it with you. Ask if you need any other part, I'm sure I have it ;-)
click on the picture name to open it. PM me if you want to buy it or post a comment if it helps the community.
Shipping is possible worlwide and the prices vary in package size and weight. I will charge you only my costs.
Lets begin with not working motors. You can get a 5 phase motor and repair it or use spare parts of it. It is an Excel list and a picture of the list is attached.
Asking 40€ for 1 motor without any extra parts (PAS, throttle, display, etc)
Part ID Number Description Work Required Winding No. Winding Type
HXM 011 1000W O/B Currently using old bearings. If possible to fit all current controller upgrades and new bearing design. SD-HX-HS-01 High speed winding 27 T, 5 conductor ,25 SWG
HXM 012 O/B Check Winding. Needs full upgrade to new bearings and all controller and cable modifications. STG-HX-HS-05 High speed winding 27 T, 5 conductor ,25 SWG
HXM 013 O/B Check Winding. Needs full upgrade to new bearings and all controller and cable modifications. STG-HX-HS-04 High speed winding 27 T, 5 conductor ,25 SWG
HXM 014 O/B Check Winding. Needs full upgrade to new bearings and all controller and cable modifications. SC-Hx-SS-02 Slow speed winding 37T,4 conductor ,25SWG
HXM 015 O/B Check Winding. Needs full upgrade to new bearings and all controller and cable modifications. SC-Hx-SS-03 Slow speed winding 37T,4 conductor ,25SWG
HXM 016 O/B Check Winding. Needs full upgrade to new bearings and all controller and cable modifications. SC-HX-SS-09 Slow speed winding 37T,4 conductor ,25SWG
HXM 017 O/B Check Winding. Needs full upgrade to new bearings and all controller and cable modifications. SC-HX-SS-04 Slow speed winding 37T,4 conductor ,25SWG
HXM 018 O/B Check Winding. Needs full upgrade to new bearings and all controller and cable modifications. SC-Hx-SS-07 Slow speed winding 37T,4 conductor ,25SWG
HXM 019 O/B Check Winding. Needs full upgrade to new bearings and all controller and cable modifications. SC-Hx-SS-06 Slow speed winding 37T,4 conductor ,25SWG
HXM 020 O/B Check Winding. Needs full upgrade to new bearings and all controller and cable modifications. SC-Hx-SS-05 Slow speed winding 37T,4 conductor ,25SWG
HXM 021 O/B Check Winding. Needs full upgrade to new bearings and all controller and cable modifications.
HXM 056 N/B update to suit
HXM 057 N/B update to suit SC-Hx-SS-26 Slow speed winding 37T,4 conductor ,25SWG
HXM 058 N/B update to suit STG-Hx-USS-09 Ultra slow speed 54T,2conductor,23 SWG
HXM 059 N/B update to suit SC-Hx-HS-20 High speed winding 27 T, 5 conductor ,25 SWG
HXM 060 N/B update to suit SC-Hx-HS-16 High speed winding 27 T, 5 conductor ,25 SWG
HXM 093 HSW TH, controller and cable upgrade. Sidecovers to be replaced due to stripped threads. Also needs new FW&Disc adaptors. SC-HX-HS-91 High speed winding 27 T, 5 conductor ,25 SWG
HXM 095 Ali Pipe Snapped bolt in Ali Pipe we could not remove. Magnets loose. SC-HX-HS-64 High speed winding 27 T, 5 conductor ,25 SWG
HXM 096 HSW TH, controller and cable upgrades. Needs new FW and disc Adaptors. SC-HX-HS-83 High speed winding 27 T, 5 conductor ,25 SWG
HXM 097 HSW TH+Controller and cable upgrades. new FW adaptor. SC-HX-HS-44 High speed winding 27 T, 5 conductor ,25 SWG
HXM 098 HSW TH, controller and cable upgrades. Needs new side covers due to damaged threads and new adaptors. SC-HX-HS-78 High speed winding 27 T, 5 conductor ,25 SWG
HXM 122 SSW ??????? SC-HX-SS-33 Slow speed winding 37T,4 conductor ,25SWG
HXM 128 SSW ??????? SC-HX-SS-15 Slow speed winding 37T,4 conductor ,25SWG
HXM 129 SSW 42V 500W 20A SC-HX-SS-39 Slow speed winding 37T,4 conductor ,25SWG
HXM 130 SSW ??????? SC-HX-SS-43 Slow speed winding 37T,4 conductor ,25SWG
HXM 131 SSW ??????? SC-HX-SS-21 Slow speed winding 37T,4 conductor ,25SWG
HXM 132 SSW` ??????? SC-HX-SS-22 Slow speed winding 37T,4 conductor ,25SWG
HXM 133 SSW ??????? SC-HX-SS-33 Slow speed winding 37T,4 conductor ,25SWG
HXM 143 SSW ??????? SC-HX-SS-40 Slow speed winding 37T,4 conductor ,25SWG
HXM 144 SSW ??????? SC-HX-SS-28 Slow speed winding 37T,4 conductor ,25SWG
HXM 150 HSW TH, controller and cable upgrades. Ali Pipe needs to be replaced as bolt holes not drilled in correct places. Also requires new side covers as the paint is terrible and replacement adaptors. SC-HS-22 High speed winding 27 T, 5 conductor ,25 SWG
HXM 158 HSW 42V 500W 20A, Motor returned to us because of strange regen sensation above 20-25mph. Needs to be investigated and upgraded. SC-HS-30 High speed winding 27 T, 5 conductor ,25 SWG
HXM 319 Stator only Motor had very bad bearing play. Stripped the motor for parts. Pease change the axel and rebuild the motor. SC-HX-HS-04 High speed winding 27 T, 5 conductor ,25 SWG
HXM 323 Stator only Motor was stripped to replace the Ali Pipe, we could only find Ali Pipes with loose magnets so could not rebuild. Needs to be tested and rebuilt into a hub. SC-HX-HS-105 High speed winding 27 T, 5 conductor ,25 SWG
HXM 345 HSW Needs new axel with tighter tolerances as the motor case slides across the axel. SC-HX-HS-86 High speed winding 27 T, 5 conductor ,25 SWG
HXM 409 Stator only Motor stripped for parts as controller was damaged by customer bad power connection. Assess and repair damage. Rebuild motor. SC-HX-HS-99 High speed winding 27 T, 5 conductor ,25 SWG
HXM 428 Stator only Motor was stripped to replace the Ali Pipe, we could only find Ali Pipes with loose magnets so could not rebuild. Needs to be tested and rebuilt into a hub. SC-HX-HS-14 High speed winding 27 T, 5 conductor ,25 SWG
No Motor No. 1 HSW TH, controller and cable upgrades. Check all bolt threads. Needs new FW and Disc adaptors.
HXM 441 55V 250W 35A, Juddering badly, no assistance, no 5V
HXM 590 55V 500W 35A, ???
HXM 593 55V 500W 35A, ??? 1 broke bolt
HXM 592 55V 500W 35A, programmed, but was trapped
HXM 513 55V 500W 35A, ???
HXM 063 silver ???????
HXM 386 55V 250W 35A, ???
HXM 431 55V 250W 35A, ???
HXM 154 42V 500W 20A, ???
HXM 528 55V 250W 35A, ???
HXM 300 50V 750W 45A, ???
HXM 357 50V 750W 45A, ???
HXM 298 50V 750W 45A, ???
HXM 351 36V 250W 17A, REPLACE CS CABLE
HXM 292 42V 500W 35A, ???
HXM 390 36V 250W 17A
HXM 406 55V 250W 35A, Juddering badly, no assistance, no 5V
Adapters for side plate:
Disc Brake Adapter (Falco is asking $29), selling it for used 7€
Free Wheel Adapter (instead of $29) used 7€
Falco motors used.pdf
(52.76 KiB) Downloaded 174 times
burner77   100 W
Spacers
Post by burner77 » Jun 15 2015 11:13am
Axle Spacers (instead of $29) used 7€
Axle Washer Set of 3 ($7) 3€
Disk Brake Spacer (29$) used 7€
Axle nut (19$) used 3€
Torque arm set (29$) 14€
Torque bar washer antitrotation nut (19$) used 3€
burner77   100 W
Consoles
Post by burner77 » Jun 15 2015 11:20am
USB Charger with UK plug and USB cable (instead of $29) 7€
Wireless Module Connector motor -> display ($49) new 19€, used but not tested, selling as broken 3€
Consoles without charger. I have new and used ones. I can test the used ones, but can not guarantee, they are fully working, because I can't test all the functions. I have plenty of consoles with issues as well. If you need parts, let me know.
Consoles with issues 5€, Used working ones 10€, Brandnew 49€
Console holder for bar 2€
burner77   100 W
Sensors
Post by burner77 » Jun 15 2015 11:22am
PAS Crank Sensor ($29) used 4€, new 9€
burner77   100 W
Falco bottle battery 36V 11.6 Ah 10s4p with charger
Post by burner77 » Jun 15 2015 11:28am
New unused 36V, 11.6Ah Bottle Mount Lithium Ion Manganese Panasonic (Cell Model NCR18650PD).
Comes with charger 2.35A (British plug) and bottle mount holder with keys.
Asking 260€ plus shipping (which is 6.25€ per cell).
The pack merely weights 2.5 kg (5.4 lbs.) and it delivers 417Wh of energy. The pack has a number of primary as well as secondary protections. There is a On/Off switch and some LEDs showing the status of the battery.
The packs are equipped with the following features and benefits: over current protection, cell balancing temperature protection, over current and temperature protection, (In-built Falco battery management System (BMS), water-resistant and firm ABS plastic casing. Overcurrent protection is 40A, but rated less for continuos use. On the end of the cable of the bottle mount is no plug.
For more information:
http://electricbicycleworld.com/li-3/
burner77   100 W
+/- Button
Post by burner77 » Jun 15 2015 11:31am
(instead of 29$), used and tested 5€, new 9€
burner77   100 W
Re: Falco e-Motors
Post by burner77 » Jun 15 2015 12:00pm
I have bought plenty of Falco parts and opened another thread. Let me know if you need anything or you have questions:
http://endless-sphere.com/forums/viewto ... 3#p1060103
burner77   100 W
New motors
Post by burner77 » Jun 15 2015 12:04pm
I also have many new motors and parts. But for some reason they have to be reprogrammed with a new software and I'm waiting for a programming cable. Actually I'm not able to get the motors running or I'm too stupid. They are brandnew and unpacked.
If you want any new part, let me know.
Asking 199€ for a new motor:
HXM 296 SSW 42V 500W
HXM 286 SSW 42V 500W
HXM 289 SSW 42V 500W
HXM 290 SSW 42V 500W
HXM 293 SSW 42V 500W
HXM 294 SSW 42V 500W
HXM 295 SSW 42V 500W
HXM 297 SSW 42V 500W
HXM 413 HSW 55V 250W
HXM 514 HSW 55V 500W
HXM 516 HSW 55V 500W
HXM 518 HSW 55V 500W
HXM 519 HSW 55V 500W
HXM 524 HSW 55V 500W
HXM 526 HSW 55V 500W
HXM 648 HSW 42V 500W
HXM 656 HSW 42V 500W
HXM 659 HSW 42V 500W
HXM 661 HSW 42V 500W
HSW = High Speed Winding, SSW = Slow Speed Winding (but more torque)
Triketech   1 kW
Re: many Falco motors and parts for sale
Post by Triketech » Jun 15 2015 7:16pm
Whats the price on a new HXM500 with the little ant thing and cables/switches?
Basically a complete unit without the battery.
Do they all need reprogramming?
Best guess on shipping cost to the USA?
Do you know which thermister they have?
burner77   100 W
Post by burner77 » Jun 16 2015 4:54am
Triketech wrote:Whats the price on a new HXM500 with the little ant thing and cables/switches?
Hi Triketech,
there is a 42 and a 55V version of it and I can send it to your place.
I have tested a few and it looks they have to be reprogrammed, since they are brandnew and packed originally.
I don't know which thermistor is inside.
Price for a new kit wth new parts including shipping would be 290$
littleskull99   100 W
Re: Falco e-Motors auction
Post by littleskull99 » Jun 16 2015 12:02pm
Pm sent re disc brake adapters. Thanks.
littleskull99   100 W
Post by littleskull99 » Jun 20 2015 11:42am
Received disc brake adapters. Burner77 is a good solid seller. Would use again. Cheers patrick.
Matt.
burner77   100 W
Post by burner77 » Jun 20 2015 11:51am
littleskull99 wrote:Received disc brake adapters. Burner77 is a good solid seller. Would use again. Cheers patrick.
Matt.
Thanks for the feedback and have fun!
burner77   100 W
Post by burner77 » Nov 03 2015 5:11am
All the new motors are working now and have the latest open firmware, going 40 km/h+ with 36V HSW
There are Slow Speed Windings SSW (more torque at lower speed) and High Speed Windings HSW available.
HSW or SSW for 42V and 35A = up to 1.500W
HSW for 55V and 35 = up to 2.000W
Motors are going for sale for 200€, incl. the PAS Sensor, battery connector from Delphi.
and an extra 50€ for the display, the +/- button, ANT+ module and the display charger. Motor is also working without display.
extra 14€ for the torque arm.
or 250€ for the whole kit
Alle new and tested. This kit is sold with 1.000€ on the Falco website.
I like the motor because of its easy & fast setup and not many wires because of its integrated controller.
Shipping is available to any country, about 50$ to the US. Ask for rates to your country
jefflum11   1 µW
Re: many Falco motors and parts for sale (also new)
Post by jefflum11 » Nov 08 2015 8:27pm
pm sent
burner77   100 W
Post by burner77 » Nov 09 2015 8:57am
The motors are available in the legal or open off-road version
Tell me which one you want and I will prepare it for you
Cyberbob   1 µW
Post by Cyberbob » Aug 07 2016 2:53am
Do you have still someone Falco Motor Kits available?
burner77   100 W
Post by burner77 » Aug 07 2016 3:17am
Yes I have some 42V kits, let me know…
lameduck   10 mW
Post by lameduck » Aug 07 2016 11:39am
Do you have any consoles with the off road unlock option (allows 28MPH)? And do the motors have the torque sensor in them?
burner77   100 W
Post by burner77 » Aug 07 2016 1:05pm
lameduck wrote:Do you have any consoles with the off road unlock option (allows 28MPH)? And do the motors have the torque sensor in them?
All motors are unlocked and have the torque sensor integrated, but usually the angle of the dropout has to be adjusted by software. You need a Ant+ USB for your laptop, the software is free
nocny__marek   1 µW
Post by nocny__marek » Aug 15 2016 1:15pm
if you have a throttle or Thumb Throttle for FALCO?
how much it costs with shipping to Poland
burner77   100 W
Post by burner77 » Aug 15 2016 1:36pm
nocny__marek wrote:if you have a throttle or Thumb Throttle for FALCO?
Hi Marek,
I do have some twist throttles like this:
http://www.electricbicycleworld.com/fal ... -60-cable/
for 29 € shipped. PayPal or wire transfer is possible. Please contact me by email: welcome@fasterbikes.eu
nocny__marek   1 µW
Post by nocny__marek » Oct 11 2016 7:13am
Hello
I have already bought motor Falco. Now I want to program it
needs a follows; elements:
Hx Motor Programmer
Free Wheel Adapter
Axle Nut x4,
Torque Arm,
Y-Connector
The most important to me:
Hx Motor Programmer.
ask for the price and / including shipping.
if this can be measured, please various options (price + shipping
to Poland) or single elements:
1.
2.
Axle Nut x2.
3.
Axle Nut x4.
Free Wheel Adapter
4.
Axle Nut x4.
Free Wheel Adapter
Torque Arm,
Y-Connector
Regards
Marcin Chyła
elektrikflo   10 µW
10 µW
Post by elektrikflo » May 07 2017 5:35pm
Do you still have engines for sale?
