Monstarr
These LG Chem built modules contain very high quality NMC pouch power parallel 15 ah cells from LG Chem configured in 37V30Ah - 10S2P order for 1100 Wh's of capacity. The rigid steel OEM sideplates provides excellent compression and has connection for watercooling system. It has a plastic protective cover over the cell tabs and terminals and there is a direct balance lead connection and two connectors for the thermistors (blue wires) built in the pack.
Balance pin-out of the 14 pin connector (Molex Microfit 3.0 - MX-43025-1400) - cable is not included.
1 X X X X 10 9
2 3 4 5 6 7 8
Cell 1 connect to - gives single cell voltage
Cell 10 connect to - gives full pack voltage
The same cells are also used for example in Opel Ampera/Chevy Volt/Renault Zoe packs.
These modules are excellent for slim light-weight powerpacks in scooters, cargobikes etc.
Weighing around 10 KG.
The onboard electronics board is a cell voltage & temperature node and sends information by CAN bus to the pack's main hub.
It doesn't really have any value to DIY because you need to reverse engineer the whole protocol and CAN language. Besides, it will only tell you monitoring information. It can't shut down the power like a BMS can.
Dimensions:
130 mm wide
280 mm high
320 mm long (w/o coolant tubes 300 mm)
The modules currently have a storage voltage and are stored dry.
Modules are located in Breda, The Netherlands, Europe.
Shipping optional if possible. PM for more info.
Price:
1 module: € 175
2+ modules: € 150/pc
per 2 with original flexible high current interconnect for series connection.
If any questions, feel free to ask.
Warning:
**Use this modules only with appropriate BMS with balancing, monitoring and shutoff protection and protective encasing against shock and environment**
**Don't charge at low temperatures**
20/11/18: No more available
1 X X X X 10 9
2 3 4 5 6 7 8
Dimensions:
130 mm wide
280 mm high
Price:
1 module: € 175
Warning:
